Ansys Free Student Software
Ansys workbench (19) solution status window missing
    • RossGrg
      Hi, I cannot seem to locate my solution status window. I have already tried resetting my layout but that did not help. Would anyone here have any idea on how I can get it to magically reappear again?
      roshan
    • Aniket
      1. Close all the Workbench sessions and then rename the v190 folders from %APPDATA%ansys to v190.old (where %APPDATA% is where your APPDATA variable is set. Just type %APPDATA% in the Explorer Address bar" and it will take you there).
      2. Close all the Workbench sessions and rename .ansys from %TEMP% to old.ansys (same as above, just type: %TEMP% in the address bar)
  • The topic ‘Ansys workbench (19) solution status window missing’ is closed to new replies.
