August 21, 2018 at 9:55 pm
emmanuel_amoako_00
Subscriber -
August 21, 2018 at 11:06 pm
Sandeep Medikonda
Ansys EmployeeHi Emmanuel,
 In workbench additive, the laser power is not directly input but instead back-calculated based on the energy density. Which is then calculated based on some of the other input parameters such as temperature, laser scanning speed etc. So when the scanning speed is increased, the energy density is decreased (Tian et al. 2008, page 1905-1906).
Sandeep.
August 21, 2018 at 11:25 pm
emmanuel_amoako_00
SubscriberHello Sandeep,
Please that was very educative, please can I get access to the reference (Tian et al. 2008).
Emmanuel -
August 21, 2018 at 11:32 pm
Sandeep Medikonda
Ansys EmployeeEmmanuel,
 I won't be able to download or attach the document due to copyright agreements, but I will try and see if I can get a DOI link, I will post it here and you should be able to access it through your school library.
Sandeep
August 21, 2018 at 11:40 pm
emmanuel_amoako_00
SubscriberSandeep,Â
Thank you very much, I would be very grateful if I get access to the DOI link.
Please can I write my own script or user defined functions in Ansys workbench additive and if yes can I get resources to help me.
Emmanuel. -
August 21, 2018 at 11:55 pm
Sandeep Medikonda
 You can write your own extensions using the ACTs in Python. You can also link them to APDL code if needed.
 See if the following resources help in getting started:
Sandeep
August 22, 2018 at 12:15 am
emmanuel_amoako_00
SubscriberSandeep,Â
Thank you so much. I will access them and am very sure it will help me get started.
Emmanuel. -
August 23, 2018 at 12:00 pm
Sandeep Medikonda
 You can access the article here.
 Also, I've had a chance to interact with the developer and was told that we don't consider the power of the laser in the calculation. So, we heat the imprinted layer just enough for it to reach the melting temperature. Not more, not less.
 Hope this helps.
Sandeep
August 23, 2018 at 1:46 pm
emmanuel_amoako_00
Thank you for the access to the article, I am very grateful.
Since the developer didn't consider the power of the laser can I develop my own script to use laser power as one of the build setting in the additive manufacturing wizard? I wanted to vary the laser power, scanning speed, hatch spacing and deposition thickness in my work.
Emmanuel. -
August 23, 2018 at 2:32 pm
Sandeep Medikonda
 Yes, you might be able to do that with ACT scripting. I don't think you can change the wizard all that much as you don't have access to the source code.
 Have you considered Additive Print for this? If you select a thermal simulation in Additive Print, you should be able to specify all these machine parameters.
Sandeep
August 23, 2018 at 2:50 pm
emmanuel_amoako_00
I have considered Additive Print, but I dont get the temperature distribution profile as a function of time in the Additive Print and also the materials(316L Stainless Steel and Ti-6Al-4v) under consideration for thermal simulation has not been validated but Workbench 19.0 gives me the access to these materials and gives the temperature distribution profile as well during the build. The only limitation is the laser power in the Workbench 19.0 but I will try the ACT scripting.
Emmanuel. -
August 14, 2019 at 10:33 am
DBStudent92
SubscriberHi Emmanuel,
did you solved the laser temperature problem in ANSYS Workbench? How is the relation between laser temperature and laser power?
I have the same problem and would be very grateful if you explain it to me.
Thanks
January 18, 2023 at 7:08 pm
Hasan Ilker ÇELİKER
Subscriberhello, how can we enter the energy density? i clicked the links above but they are all dead links
- The topic ‘ANSYS Workbench 19.0’ is closed to new replies.
2979
970
857
750
599
