July 7, 2020 at 8:15 am
alexandre.gomes
SubscriberDear all,
Can anyone help me solve this problem? I am trying to do a solution combination but i am getting the following message:
problem: Exception type:
| Error message: expected float, got str
July 7, 2020 at 10:11 am
Forum ModeratorPlease re-post the image in with the text as staff are not permitted to open or download attachments.Â
July 7, 2020 at 10:35 am
July 7, 2020 at 10:37 am
alexandre.gomes
SubscriberI am trying to do a solution combination but i am getting the following message:
When i change the Worksheet Type to Single Legacy I am able to run the simulation and get the combinations I need, I just wanted to understand why this is happening withe the Multiple.
Thank you very much.
July 10, 2020 at 4:25 pm
Aniket
Forum ModeratorI couldn't find any instance of this error that has occurred before, but I am curious if you add a base case, does it give the same error?
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
- The topic ‘Ansys WB R3’ is closed to new replies.
4939
1639
1386
1242
