December 27, 2024 at 2:15 am
Emmanuel-akor
SubscriberHi all,
I am working on the 3D-1D coupling of airflow in the airway tree. As such I need to couple my 3D model in Ansys Fluent with my 1D model in MATLAB. The 1D model will serve as my user-defined boundary condition for the 3D model outlets. I have attempted running a sample .c code for my udf but have been unable to get my code to compile. I am using visual studio as my compiler. Under environmental variables, i have added the PATH (C:\Program Files\MATLAB\R2023b\bin\win64 and C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.38.33130\bin\Hostx64\x64) , INCLUDE (C:\Program Files\MATLAB\R2023a\extern\include), and LIB (C:\Program Files\MATLAB\R2023a\extern\lib\win64\microsoft) for MATLAB. I believe I have done everything i need to do but I still end up with error messages below. It seems as though the compiler isnt finding the MATLAB LIB although i have specified it under environmental variables. Any help with this would be very much appreciated. I have tried alot of online suggestions and spent two long weeks trying to figure this out and still don't have a solution.
Error Message
Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.
Compiler and linker: Microsoft Visual C++
# Generating ud_io1.h
Testcode.c
# Generating udf_names.c because of makefile Testcode.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj Testcode.obj
Creating library libudf.lib and object libudf.exp
Testcode.obj : error LNK2019: unresolved external symbol engEvalString referenced in function matlab_test
Testcode.obj : error LNK2019: unresolved external symbol engOpen referenced in function matlab_test
Testcode.obj : error LNK2019: unresolved external symbol engClose referenced in function matlab_test
libudf.dll : fatal error LNK1120: 3 unresolved externals
NMAKE : U1077: 'link -nologo /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v242\fluent"\fluent24.2.0\win64\3d_node /Libpath:"C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v242\fluent"\fluent24.2.0\multiport\win64\mpi\shared /dll /out:libudf.dll udf_names.obj Testcode.obj mport.lib fl_mpi2420.lib ' : return code '0x460'
Stop.
UDF Code
#include "udf.h" // Fluent UDF header
#include "engine.h" // MATLAB Engine header
#include// Example UDF using MATLAB Engine
DEFINE_EXECUTE_AT_END(matlab_test)
Engine *ep = engOpen(NULL); // Open MATLAB engine
if (ep == NULL)
Message("Error: Unable to start MATLAB engine.\n");
return;
}Message("MATLAB engine started successfully.\n");
// Example MATLAB engine command
engEvalString(ep, "disp('Hello from MATLAB Engine!');");engClose(ep); // Close MATLAB engine
Message("MATLAB engine closed successfully.\n");
January 2, 2025 at 3:19 pm
Forum ModeratorNothing in the UDF manual so I'm a little stuck. Have a look for "Matlab" on here and and the other bits of the system (Search at the top of the page) as it's bound to have come up before.
January 8, 2025 at 6:44 pm
Emmanuel-akor
SubscriberOkay, will do. thank you.
5754
