December 6, 2021 at 9:12 am
NBrtc
SubscriberHello,
I have found online these old Ansys Tutorials for the Magnetostatic (Mechanical) Analysis System.
 http://oss.jishulink.com/caenet/forums/upload/2013/04/03/261/11717893008293.pdf
http://oss.jishulink.com/caenet/forums/upload/2013/04/03/261/11723694506628.pdf
http://oss.jishulink.com/caenet/forums/upload/2013/04/03/261/11738752305125.pdf
http://oss.jishulink.com/caenet/forums/upload/2015/09/03/389/180225115606566.pdf
http://oss.jishulink.com/caenet/forums/upload/2013/04/03/261/11761674202539.pdf
On the slides there's a label that says "Ansys Training Manual". Where can I download the related files?
I could not find any other training material on the topic here on Learning Hub nor anywhere else. Is there anything available?
Thanks
December 7, 2021 at 10:43 amNKC
Forum ModeratorHi @NBrtc That Ansys training material is only available for paid customers.
But Ansys is building an open free knowledge platform. Visit Ansys Innovation Courses
What exactly are you looking for?
Regards Navya
December 7, 2021 at 4:01 pmNBrtc
SubscriberHi Navya thank you for your answer. My company is an Ansys Channel Partner and we are supporting a client whose license is Mechanical Enterprise, so EMAG enables magnetostatic analyses without the need for Maxwell and new licences, while providing a familiar environment for Mechanical users.
I've checked Ansys Innovation as you suggested but I didn't see anything specifically EMAG related. The physics lessons were the closesest thing, but I need material on the software tool. Those tutorial files (or others if there are) would therefore be very useful. I could not find them nor anything else regarding EMAG.
As Channel Partners I think we have access to training material, isn't everything on Learning Hub?
Thanks again and best regards.
December 14, 2021 at 1:05 pmNKC
Forum ModeratorHi @NBrtc As an Ansys employee, I can not access the attachments from an open forum like this. So, I don't know what exactly is in the attachments you have provided.
Yes, If you have access to the learning hub, that's what I am talking about.
Ansys innovation courses just started and is evolving.
I suggest you open a service request if you have further queries as no file sharing and discussions related to the Learning hub can be done on this Open forum.
Regards Navya
Viewing 3 reply threads- The topic ‘Ansys Tutorials for the Magnetostatic (Mechanical) Analysis System’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
3977
1461
1272
1124
