Ansys Temperature dependent Properties
    • Mayur.Lokhande
      Heat exchanger geometry: It contains multiple flow path at various temperature ( -20, 20, 50, 80 & 100)
      Query: While defining material properties in Ansys, do we need to give temperature dependent young modulus, SS-cure for plasticity, thermal coeff. of expansion, thermal conductivity etc? or single room temperature data of material is sufficient?
      If single data is enough, how ansys will carry out the calculations at various temperatures?
    • Surya Prakash
      Hi Mayur,
      Please check this KM which discusses about the same.
      /knowledge/forums/topic/how-ansys-gets-temperature-dependent-material-properties-that-are-define-in-engineering-data-for-example-youngs-modulus-specified-at-23-c-and-100-c-based-on-experimental-data-and-static-analysis-i/
      Thanks,
      Surya
  • The topic ‘Ansys Temperature dependent Properties’ is closed to new replies.
