July 8, 2021 at 1:22 pm
JessG
SubscriberHi,
I've been trying to install Ansys Student 2021 R1 as well as 2020 R2 for a couple times now, but it always gave me the following error message:
"The installation completed with warnings/errors. Review any .err or .log files in: C:Program FilesANSYS IncANSYS Student"
I've pasted parts of the content of the .err file below (quite a bunch of errors so too long to paste the entire thing; they do seem to be repetitive though):
###### Error #######
  Error executing configuration script 'C:UsersJGAppDataLocalTempans_install_tmp49144configAnsConfigCommon.tcl'
  '"C:UsersJGAppDataLocalTempans_install_tmp49144 clinwinx64 clsh.exe" "C:UsersJGAppDataLocalTempans_install_tmp49144configAnsConfigCommon.tcl" -installdir "C:Program FilesANSYS IncANSYS Student" -rev 211 -dotrev 2021 R1 -scripttosource "C:UsersJGAppDataLocalTempans_install_tmp49144configConfigCommon.tcl" -sourcedir "C:UsersJGAppDataLocalTempans_install_tmp49144" -os_lang de -install ' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
  child process exited abnormally
    while executing
  "exec $cmdPath -install "$qaServicesEnabled_Arg""
    invoked from within
  "if { $config == 1 || $unconfig == 1 } {
   set config_dir "$installDir\v$revn\commonfiles\configs\winx64"
   set ANSYSLIC_DIR "$installDir\shared..."
    (file "C:UsersJGAppDataLocalTempans_install_tmp49144configAnsConfigCommon.tcl" line 27)
Any help is much appreciated!
Many thanks,
Jess
July 9, 2021 at 12:54 pmGeorge Karnos
Ansys EmployeeWhen starting the installation, did you right-click on setup.exe and choose more->run as administrator?
July 9, 2021 at 1:07 pmJessG
SubscriberYes I did.
July 9, 2021 at 1:26 pmGeorge Karnos
Ansys EmployeeCan you try changing the OS language to English?
July 9, 2021 at 1:48 pmJessG
SubscriberNot sure. Why would that help?
Viewing 4 reply threads- The topic ‘Ansys Student Installation with Errors’ is closed to new replies.
3572
1193
1076
1063
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
