August 14, 2024 at 4:12 pm
scabo
SubscriberHi
I was running an usteady simulation but it stopped due to PC suddenly restarting. Can i recover the already run files? I can see some .hsf animation files in dp0>fluent. Can i get the last result or any result?Â
August 14, 2024 at 4:20 pm
Forum ModeratorIf you were in Workbench it's trickier. Did you set autosave?Â
August 14, 2024 at 7:43 pm
scabo
SubscriberHi,
Yes i am using workbench. I used autosave every 0 time step. So i guess the files are not saved right?
August 15, 2024 at 8:36 am
Forum ModeratorEvery 0 means it's off. Unless you're using geometry parameters export the initial case & data (ie once Fluent is set up) and run Fluent from the Start menu. Set autosave to a sensible name and directory & run. If/when the PC or solver fails restart, read in case & data and continue.Â
August 18, 2024 at 1:25 am
scabo
Subscriberokay
Viewing 4 reply threads
