ANSYS static structural error
    • riteshnw
      Hello all,
      I am trying to do the ANSYS static structural simulation on my assembly component.
      And it is showing error. I have used mesh size for wings= 3mm and for ring= 10mm.
      Meshing is done properly but when I start the simulation it doesn't solve.
      The assembly is underground and it is surrounded by the wooden pellets and working condition is 40 degrees celsius.
      I want to check for the deflection and stresses produced in the components while removing from the ground having wooden pellets.
      Please provide a lot more detailed information and insert some images to show your model, the BCs and Loads, the Analysis Settings and the error.
    • riteshnw
      the error is:
      An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes.
      Warning:
      At least one body has been found to have only 1 element in at least 2 directions along with reduced integration.  This situation can lead to invalid results.  Consider changing to full integration element control or meshing with more elements.  Refer to Troubleshooting in the Help System for more details.
      You are using a very old version of ANSYS.  Release 14 doesn't have the improvements that went in over the last 6 years to make it easy to resolve problems. For example, in the current version there is a menu pick to Show Bodies with 1 element in 2 directions.  I don't know if that is available in Release 14. Please try to upgrade to the latest version.
      You will have to go through your model, body-by-body until you find the long thin body that has only 1 element in 2 directions, and add a mesh control to make sure that there are at least 2 elements across the thickness. Then try to solve again.
    • riteshnw
      Ok. Thank you Peter.
      I will upgrade my ansys version and will try one more time.
    • riteshnw
      Dear all,
      Now I am having these two errors after starting to solve the simulation:
      1. At least one body has been found to have only 1 element in at least 2 directions along with reduced integration.  This situation can lead to invalid results or solver pivot errors.  Consider changing to full integration element control or meshing with more elements.  Offending bodies can be identified by Right-clicking in the Geometry window and choose Go To -> Bodies With One Element Through the Thickness.  Refer to Troubleshooting in the Help System for more details.
      2. One or more bodies may be underconstrained and experiencing rigid body motion. Weak springs have been added to attain a solution.  Refer to Troubleshooting in the Help System for more details.
      1. Offending bodies can be identified by Right-clicking in the Geometry window and choose Go To -> Bodies With One Element Through the Thickness.  Notice how much more helpful this warning is compared with the old release.
      2. This is a warning, not an error, and may have nothing to do with the reason why the model failed to solve.
      The error message tells you to look at the Solver Output. Click on the Solution Information folder under the Solution branch of the outline. The first line has a pull down, and Solver Output is one choice, and is the default.  There will be a long text file in the main window. Crtl-F will allow you to search for the word error and see what it says.
    • riteshnw
      Following is the data inside text file.
      *** NOTE ***                            CP =       0.484   TIME= 14:00:21
       The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
       solution.  Command is ignored.
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  14.0058333
       TITLE=
       H-EX.0--Static Structural (A5)
       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
        TYPE=STRI  DIMENSIONS=      248        1        1
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001_ProjectScratchScr1A86
       SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
       PARAMETER _WB_SOLVERFILES_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001H-EX.0_filesdp0SYSMECH
       SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
       PARAMETER _WB_USERFILES_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001H-EX.0_filesuser_files
       --- Data in consistent NMM units. See Solving Units in the help system for more
       MPA UNITS SPECIFIED FOR INTERNAL
        LENGTH      = MILLIMETERS (mm)
        MASS        = TONNE (Mg)
        TIME        = SECONDS (sec)
        TEMPERATURE = CELSIUS (C)
        TOFFSET     = 273.0
        FORCE       = NEWTON (N)
        HEAT        = MILLIJOULES (mJ)
       INPUT  UNITS ARE ALSO SET TO MPA
       *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2019 R1          19.3     ***
       DISTRIBUTED ANSYS Mechanical Enterprise
       00000000  VERSION=WINDOWS x64   14:00:21  MAY 02, 2019 CP=      0.546
                ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
       *********** Nodes for the whole assembly ***********
       Database allocation failed  idbptr=      6448218240  nPageInCore=       16384  -db       -2048 set
       *** ERROR ***                           CP =      49.484   TIME= 14:021
       An unexpected error ( SIG$SEGV ) has occurred...  ANSYS internal data
       has been corrupted.  ANSYS is unable to recover and will terminate.
       Previously saved files are unaffected.  Please send the data leading
       to this operation to your technical support provider, as this will
       allow ANSYS, Inc to improve the program.
       Current ANSYS Traceback:
           ndputList_mp
           ndputList
           nblock-store
           nblock
           pr7nod
           prep7
           prepcl
           ANSYS
       ERROR: Slave process(es) with rank(s) 1 have encountered a FATAL error.
       The information below was gathered from the file*.out output file(s).
       Please review the slave process output file(s) listed below for more
       details on this error.
       Slave Process Output File .file1.out:
       *** FATAL ***                           CP =       0.312   TIME= 14:024
       Check processor 0 (master) for error message(s).
      That is saying the computer does not have enough RAM to run this model.
      Please reply with your computer specs.
    • riteshnw
       I have 8 GB ram in my computer.
      Your computer has 2 cores. Maybe ANSYS 2019R1 defaults to 4 cores?
      In Mechanical, find the menu that has Solve Process Settings and open that.
      Click on the Advanced Button.
      Where it says Number of Cores, type 2.
      Did that help?
    • riteshnw
      Should I change all the 3 values? If yes, which value should I enter?
      Just change the Processors.  But this is the Options window from the Workbench program.
      I was talking about the Mechanical program.
      Tools > Solve Process Settings > My Computer > Advanced.  You get a different window.
    • riteshnw
      No. it does not work. It again shows the same error.
      The things you said were already default.
      And I also tried to change my GPU acceleration to AMD Radeon but it does not show AMD Radeon, instead it shows NVIDIA.
      and the solution information data:
         *****  ANSYS COMMAND LINE ARGUMENTS  *****
        BATCH MODE REQUESTED (-b)    = NOLIST
        INPUT FILE COPY MODE (-c)    = COPY
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     2 CORES REQUESTED
        INPUT FILE NAME              = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001_ProjectScratchScrA016dummy.dat
        OUTPUT FILE NAME             = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001_ProjectScratchScrA016solve.out
        START-UP FILE MODE           = NOREAD
        STOP FILE MODE               = NOREAD
       RELEASE= 2019 R1              BUILD= 19.3      UP20181204   VERSION=WINDOWS x64
       CURRENT JOBNAME=file0  115:23  MAY 03, 2019 CP=      0.515
       PARAMETER _DS_PROGRESS =     999.0000000
       /INPUT FILE= ds.dat  LINE=       0
       *** NOTE ***                            CP =       0.718   TIME= 115:25
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  11.5902778
       TITLE=
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001_ProjectScratchScrA016
       --- Data in consistent MKS units. See Solving Units in the help system for more
       MKS UNITS SPECIFIED FOR INTERNAL
        LENGTH        (l)  = METER (M)
        MASS          (M)  = KILOGRAM (KG)
        TIME          (t)  = SECOND (SEC)
        TEMPERATURE   (T)  = CELSIUS (C)
        TOFFSET            = 273.0
        CHARGE        (Q)  = COULOMB
        FORCE         (f)  = NEWTON (N) (KG-M/SEC2)
        HEAT               = JOULE (N-M)
        PRESSURE           = PASCAL (NEWTON/M**2)
        ENERGY        (W)  = JOULE (N-M)
        POWER         (P)  = WATT (N-M/SEC)
        CURRENT       (i)  = AMPERE (COULOMBS/SEC)
        CAPACITANCE   (C)  = FARAD
        INDUCTANCE    (L)  = HENRY
        MAGNETIC FLUX      = WEBER
        RESISTANCE    (R)  = OHM
        ELECTRIC POTENTIAL = VOLT
       INPUT  UNITS ARE ALSO SET TO MKS
       00000000  VERSION=WINDOWS x64   115:25  MAY 03, 2019 CP=      0.749
      I opened a New Discussion to ask this specific question.
    • MangeshANSYS
      Hello Ritesh,
      Are you running into the error for just this model or all the models?
      For test purposes, Can you create a very simlpe test case say a box or cylinder geometry, Linear static, one fixed support and one force, then save the project to say c:temp and run it.
      If that works then for your other project please save the project to a simple path without any spaces in the path or folder name
      i.e. instead of
      use below to save project
      D:RITESHtemp
      D:RITESHMS_Study_MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001
      see if that helps
    • Craig Rothschild
      • Craig Rothschild
        Workbench - Warning
        Consider changing to full integration element control or meshing with more elements. Offending bodies can be identified by Right-clicking in the Geometry window and choose Go To -> Bodies With One Element Through the Thickness. Refer to Troubleshooting in the Help System for more help
Viewing 16 reply threads
  • The topic ‘ANSYS static structural error’ is closed to new replies.
