July 18, 2024 at 5:56 am
Xime54
SubscriberHi everyone,Â
I have sensors in a ".scdocx" file, and my source and other stuff are located in another ".scdocx" file. I've tried to insert one file in another with conception -> add file, it works fine, but it's impossible to run a simulation, or to attribute material from a file to an element of another file. Even the "simulation" window is split between the inserted files. So is what I'm trying to do impossible, or I am doing it wrong?
Thanks.
Maxime
July 18, 2024 at 8:28 am
Thomas Martineau
Ansys EmployeeHello Maxime,
You can use a material created in the main scdoc, in a below scdocx.
Example :
You import in main scdocx called A, to assemblies B and C.
You can use a material created in A for surfaces of A, B and C.
You can use a material created in B only in B. Same for C.
It's the same for the sources.Â
Simulation created in A can include sources of A, B and C.Â
Simulation created in B can only include source of B.Â
Thanks
Thomas
July 18, 2024 at 12:52 pm
Xime54
SubscriberBonjour Thomas,Â
Merci pour cette réponse. Je ne me doutais pas qu'il y avait une hiérarchie dans les fichiers, et que l'ordre d'insertion importait: lorsqu'on le sait, tout fontionne, c'est de la magie!!
Bonne journée.Â
Maxime
- The topic ‘ANSYS SPEOS: how to run a simulation with an assembly’ is closed to new replies.
