3D Design
3D Design
Ansys SpaceClaim Linear Pattern
    • smjang
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello I inquired while using SpaceClaim's linear pattern. After modeling a simple shape, a linear pattern was activated. The pattern I want is a pattern in the x-axis direction and the z-axis direction (image file) But maybe I'm still not good at the tool, or if I click on the X, Y, Z axes of World Origin There is no pattern in the x-axis and z-axis directions. I have attached a video, please check it. (The same thing happens in Discovery Sketch mode. )
    • Charudatta Bandgar
      Hello smjang
      Even I am noticing the same behaviour, let me check whether this behaviour is intended.
      For now, the workaround would be to do one directional linear pattern in the x-direction and then these bodies as the one-directional linear pattern in the z-direction. In the meantime let me see if there is a better solution to this.
      Regards.
      Hello smjang
      This issue was identified before (bug ID: 366934) and the developers are working on it. For now, the workaround stated before can be used.
      Regards.
  • The topic ‘Ansys SpaceClaim Linear Pattern’ is closed to new replies.
