April 30, 2021 at 3:18 am
jinson
Subscriberbelow warning from event viewer
- Removal of an assembly from the global assembly cache failed: Â C:Program FilesANSYS Incv195SCDMSpaceClaim.Api.V8SpaceClaim.Api.V8.dllÂ
- System.IO.FileNotFoundException: Could not load file or assembly 'SpaceClaim.Api.V8.dll' or one of its dependencies. The system cannot find the path specified.
File name: 'SpaceClaim.Api.V8.dll' ---> System.IO.DirectoryNotFoundException: The system cannot find the path specified. (Exception from HRESULT: 0x80070003)
  at System.Reflection.AssemblyName.nGetFileInformation(String s)
  at System.Reflection.AssemblyName.GetAssemblyName(String assemblyFile)
  at System.EnterpriseServices.Internal.AssemblyManager.InternalGetGacName(String fName)
 - Removal of an assembly from the global assembly cache failed:  C:Program FilesANSYS Incv195SCDMSpaceClaim.Api.V7SpaceClaim.Api.V7.dllÂ
- System.IO.FileNotFoundException: Could not load file or assembly 'SpaceClaim.Api.V7.dll' or one of its dependencies. The system cannot find the path specified.
File name: 'SpaceClaim.Api.V7.dll' ---> System.IO.DirectoryNotFoundException: The system cannot find the path specified. (Exception from HRESULT: 0x80070003)
 - Removal of an assembly from the global assembly cache failed:  C:Program FilesANSYS Incv195SCDMSpaceClaim.Api.V6SpaceClaim.Api.V6.dllÂ
- Removal of an assembly from the global assembly cache failed: Â C:Program FilesANSYS Incv195SCDMSpaceClaim.Api.V4SpaceClaim.Api.V4.dllÂ
- Removal of an assembly from the global assembly cache failed: Â C:Program FilesANSYS Incv195SCDMSpaceClaim.Api.V3SpaceClaim.Api.V3.dllÂ
Faulting application name: SpaceClaim.exe, version: 2019.3.38912.60291, time stamp: 0x5d3f596f
Faulting module name: KERNELBASE.dll, version: 10.0.18362.1237, time stamp: 0x71e81044
Exception code: 0xe0434352
Fault offset: 0x0000000000043b29
Faulting process ID: 0x3478
Faulting application start time: 0x01d73d702a4345c8
Faulting application path: C:Program FilesANSYS Incv195SCDMSpaceClaim.exe
Faulting module path: C:WINDOWSSystem32KERNELBASE.dll
Report ID: 54df5a2f-8b85-4857-b3d5-c0dfc63fea53
Faulting package full name:Â
Faulting package-relative application ID:ÂÂ
Application: SpaceClaim.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: SpaceClaim.EvaluationDeletedException
  at SpaceClaim.Program.DomainUnhandledExceptionHandler(System.Object, System.UnhandledExceptionEventArgs) -
April 30, 2021 at 6:50 am
Charudatta Bandgar
SubscriberLet me look into this, I will get back to you.
Regards.
- The topic ‘Ansys SpaceClaim 2019R3 assembly problem’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4167
1487
1338
1171
