July 4, 2024 at 6:57 am
kiran.purushothamakeshavan
SubscriberHello,
I have been looking for a a way to simulate rain on bluff body using ROCKY SPH. I was not able to find relevant tutorials which I can use for this case, can you please tell me if its possible to have SPH injections (similar to that of DEM particle inlet in ROCKY for SPH to show rain).
This is the example to a case for your referece.
Guan, Qingyun, et al. "Rainfall simulation analysis of front windshield lower trim panel system based on SPH method."Â Transactions on Environment, Energy and Earth Sciences 1 (2023): 12-18.
Thanks,|
Kiran -
July 4, 2024 at 9:49 am
Forum ModeratorThat should be available once the SPH module is switched on. However, you may need 24R1 for the latest options. Note, 24R2 is due "soon" which is likely to have further functionality in this area.Â
- The topic ‘Ansys Rocky SPH rain’ is closed to new replies.
5794
