May 29, 2024 at 12:06 am
Yidong Xia
SubscriberWhile I have reported my issue to my regional Ansys Partner support team, we have not resolved the issue yet. So, I am trying to seek any help here when I wait for answers.
I installed only ANSYS License Manager and Rocky (2024R1) on Windows 10 (x64) from the ANSYS current release (accessed on May 28, 2024).
I loaded my purchased license file locally in Ansys License Manager, which then shows 1 Rocky PrePost license and 1 Rocky Solver license available. I can start Rocky GUI and Ansys License Manager shows 1 PrePost license in use.
But when I try to run a simulation by clicking 'Run, Rocky will show a error message window saying “Cannot find path to Solver license”. I tried several different ready-to-run simulation cases from Rocky Tutorials so I know it would not be an error from a specific simulation setup.
How can I determine if a firewall could be an issue in this case? What external website (URL) Rocky or ANSYS License Manager will try to connect to when Rocky starts to run a simulation? My institution has admin restriction to firewall configurations and thus I cannot turn off firewall settings.
May 30, 2024 at 8:08 am
Rajeshwari Jadhav
Forum ModeratorHi Yidong,
In your start menu type %temp%> .ansys> over there will be a file named "*rocky", please share screenshot of that file.
Also set the environment variable ANSYSLMD_LICENSE_FILE = portno.@servername in your system environment settings and try to relaunch the application.
May 30, 2024 at 3:35 pm
Yidong Xia
SubscriberRaj, thank you for your reply. Please see my response below per your instructions.
I assume "portno." is "port number". What does this port number can be?
The screenshot is below. I am also copying and pasting the content in the file "licdebug.INL466957.ROCKY.241" for your inspection. I do see error related messages. Hope that would give you clue how to fix the issue.
2024/05/28 15:54:21 INFO Starting Licensing Client Proxy server.2024/05/28 15:54:21 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 18268.28458 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.18268.28458.log2024/05/28 15:54:21 INFO Started ANSYSLI server.2024/05/28 15:54:22 CLIENT_CONNECT 18268:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 15:54:22 NEW_CONNECTION Connected to Licensing Client Proxy server: 53968@127.0.0.1.2024/05/28 15:54:22 CHECKOUT rocky_preppost 24.1 (2023.0823) 1/1/1/1 18268:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 15:55:03 CHECKIN rocky_preppost 24.1 (2023.0823) 1/0/0/1 18268:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 15:55:11 INFO Starting Licensing Client Proxy server.2024/05/28 15:55:11 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log2024/05/28 15:55:11 INFO Started ANSYSLI server.2024/05/28 15:55:12 CLIENT_CONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 15:55:12 NEW_CONNECTION Connected to Licensing Client Proxy server: 54019@127.0.0.1.2024/05/28 15:55:12 CHECKOUT rocky_preppost 24.1 (2023.0823) 1/1/1/1 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 15:58:50 ERROR Unable to connect to ansyscl on port 54019 as ansyscl is not currently running.2024/05/28 15:58:50 INFO Starting Licensing Client Proxy server.2024/05/28 15:58:50 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -aclport 54019 -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log2024/05/28 15:58:50 INFO Started ANSYSLI server.2024/05/28 15:59:05 CONNECT_ERROR rocky_solver 3764:ROCKY:XIAY@INL466957.inel.gov:winx64ANSYSLI exited or could not read server port ansyscl.INL466957.6764.14395.Please refer C:\Users\XIAY\AppData\Local\Temp\1\\.ansys\ansyscl.INL466957.6764.14395.log for more information.2024/05/28 15:59:05 CONNECT_ERROR rocky_solver 3764:ROCKY:XIAY@INL466957.inel.gov:winx64ANSYSLI exited or could not read server port ansyscl.INL466957.6764.14395.Please refer C:\Users\XIAY\AppData\Local\Temp\1\\.ansys\ansyscl.INL466957.6764.14395.log for more information.2024/05/28 17:14:13 HEARTBEAT 6764:ROCKY:XIAY@INL466957.inel.gov:winx64System error: 10054 "An existing connection was forcibly closed by the remote host.".2024/05/28 17:14:13 ERROR 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License Handler Disconnected: System error: 10054 "An existing connection was forcibly closed by the remote host.".2024/05/28 17:14:14 SERVER_DISCONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License server 54019@INL466957.inel.gov has disconnected unexpectedly.ANSYSLI_SERVERS: 2325@INL466957FLEXlm Servers: 1055@INL4669572024/05/28 17:15:11 INFO Starting Licensing Client Proxy server.2024/05/28 17:15:11 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log2024/05/28 17:15:11 INFO Started ANSYSLI server.2024/05/28 17:15:12 CLIENT_CONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 17:15:12 NEW_CONNECTION Connected to Licensing Client Proxy server: 62034@127.0.0.1.2024/05/28 17:15:12 RECONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/28 17:15:12 INFO 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License server connection restored.Connected to server 62034@INL466957.inel.gov.ANSYSLI_SERVERS: 2325@INL466957FLEXlm Servers: 1055@INL4669572024/05/28 17:15:12 RECHECKOUT rocky_preppost 24.1 (2023.0823) 1/1/1/1 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:41:06 HEARTBEAT 6764:ROCKY:XIAY@INL466957.inel.gov:winx64System error: 10054 "An existing connection was forcibly closed by the remote host.".2024/05/29 15:41:06 ERROR 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License Handler Disconnected: System error: 10054 "An existing connection was forcibly closed by the remote host.".2024/05/29 15:41:07 SERVER_DISCONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License server 62034@INL466957.inel.gov has disconnected unexpectedly.ANSYSLI_SERVERS: 2325@INL466957FLEXlm Servers: 1055@INL4669572024/05/29 15:41:11 INFO Starting Licensing Client Proxy server.2024/05/29 15:41:11 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log2024/05/29 15:41:12 INFO Started ANSYSLI server.2024/05/29 15:41:13 CLIENT_CONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:41:13 NEW_CONNECTION Connected to Licensing Client Proxy server: 62333@127.0.0.1.2024/05/29 15:41:13 RECONNECT 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:41:13 INFO 6764:ROCKY:XIAY@INL466957.inel.gov:winx64License server connection restored.Connected to server 62333@INL466957.inel.gov.ANSYSLI_SERVERS: 2325@INL466957FLEXlm Servers: 1055@INL4669572024/05/29 15:41:13 RECHECKOUT rocky_preppost 24.1 (2023.0823) 1/1/1/1 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:41:33 CHECKIN rocky_preppost 24.1 (2023.0823) 1/0/0/1 6764:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:51:17 INFO Starting Licensing Client Proxy server.2024/05/29 15:51:17 INFO C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 19928.41057 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.19928.41057.log2024/05/29 15:51:17 INFO Started ANSYSLI server.2024/05/29 15:51:18 CLIENT_CONNECT 19928:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:51:18 NEW_CONNECTION Connected to Licensing Client Proxy server: 65240@127.0.0.1.2024/05/29 15:51:18 CHECKOUT rocky_preppost 24.1 (2023.0823) 1/1/1/1 19928:ROCKY:XIAY@INL466957.inel.gov:winx642024/05/29 15:54:15 CHECKIN rocky_preppost 24.1 (2023.0823) 1/0/0/1 19928:ROCKY:XIAY@INL466957.inel.gov:winx64 -
May 30, 2024 at 5:16 pm
Yidong Xia
SubscriberRaj,
BTW, from early on, per my regional ANSYS support team’s suggestion, I tried adding a new environment variable like you suggested: ANSYSLMD_LICENSE_FILE = 1055@my_servername
But it did not help solve my problem. Thanks.
May 31, 2024 at 10:58 am
Rajeshwari Jadhav
Can you please download and install sp3, also may I know who is your Support Partner? Please ask them to raise a case if they can.
June 3, 2024 at 9:07 pm
Yidong Xia
SubscriberRaj,
Glad to hear from you again.
My regional supporter is PADT. Currently, Ansys contact person Vijay is in touch with me. I have installed 2024R1 SP3 but still having the issue. Vijay has all the dianostic files needed from me today to parse the issue. But please, if possible, touch base with Vijay Prithiv regarding my issue. An internal ticket has not been created yet regarding my issue, according to Vijay.
Thanks.
- The topic ‘Ansys Rocky 2024R1 shows error “Cannot find path to Solver license”’ is closed to new replies.
5799
