April 26, 2024 at 4:25 pm
Andrew
SubscriberHiÂ
I have a PCB 6 layer board which i am simulating in Ansys Q3D to extract plane inductance between two different points. Initially i defined two points as mentioned in picture as A to be the source and sink and i got about 25nH inductance i then changed the terminal and excitation to point B and added a smaller piece of sheet as well for one terminal which i unite with main plane. At point B i got like half of inductance as compared to point A. Why is this so? a difference of 1 to 2nH can be expected but this much difference is not logical at all.
Any help regarding this will be appreciated. Can i add sheet in way like i have added and unite it with board plane?
My workflow is like thisÂ
1)I connected different layers together to form a connected conductor.
2)Then i unite the whole assembly
3)Assign excitation(sorce/sink)Â to the single net
Is there something wrong with workflow?Â
May 30, 2024 at 11:39 am
Mrinmoy Bharadwaj
Ansys EmployeeHello Abdul Qadeer Khan,
The tool calculates inductance based on the geometry by generating a mesh and excitation set-up. If you do need to compare that to an analytical derivation, please try that on a simpler geometry to get better understanding and confidence over the tool before trying out on complex gemetries where analytical derivations are either very difficult or not mathematically traceable. I hope this helps.Â
May 31, 2024 at 12:29 pm
Andrew
SubscriberThanks make sense.
- The topic ‘Ansys Q3D Simulation’ is closed to new replies.
5819
