TAGGED: Ansys Discovery, FAQ, fluids, How To, profiles
July 26, 2022 at 1:41 am
lancer
SubscriberHello,
I recently encountered a problem as following as attachment. The attachment shows the 999999: mpt_accept: error: accept failed: No such file or directory.
I search the answer on the internet. However, most of them said that there is the compiled UDF was the problem. But, I am using SOFC with unresolved electrolyte which is an addon module inside the ANSYS 2021 R1. Thus, I am not using any outside UDF right now.
Anyone know how to fix the problem? -
July 26, 2022 at 1:52 am
Charudatta Bandgar
SubscriberHello Ole Ronie
If I understand correctly, SOFC with unresolved electrolyte module is for Fluent. Regarding your question on Ansys Fluent, please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Thank you for your understanding!
Regards.
July 26, 2022 at 2:38 am
lancer
SubscriberMy apology. I'll do that.
September 19, 2022 at 4:32 am
Rehan Ahmad Khan
SubscriberHi Ole,
Did your SOFC model work? I have some queries regarding the SOFC model and wanted to ask you whether you can help me with it.Â
To begin with: The geometries in the fluent are defined in terms of walls and shadow, while in normal terminology we have current collector, gas diffusion layers or interlayers, electrolyte, and electrodes. I have designed these geometries in Autodesk inventor professional and updated mesh on them in Fluent but I am not sure how to connect this normal terminology with the one defined in fluent in terms of wall or wall shadow. Can you let me know which geometry relates to what in fluent?Â
- The topic ‘ANSYS No Such file or directory’ is closed to new replies.
3492
1057
1051
965
942
