December 21, 2023 at 12:11 am
Feisal Asbaghian
SubscriberHi folks,
I want to run some jobs using the Digital Alliance of Canada and it requires. My simulations are in an ANSYS motion environment. To use their system I need to use the "write input file" feature. However, this feature seems to be unavailable for ANSYS Motion. Is there a way to fix this issue or this feature is unavailable for ANSYS motion?
Thank you,
FeisalÂ
December 21, 2023 at 2:16 pm
ErKo
Ansys EmployeeÂ
Hi
This (write input file), is to create/write Ansys apdl input files not Ansys Motion files.
To export Motion files, go to the Motion tab in the user interface, and choose export.
Alternatively:
Also the files are allready availavle when you solved the model, and can be found in the solver files directory which you can open by going to Solution (C6), and then by right mouse button clicking and choosing Open solver files directory.
Erik
- The topic ‘ANSYS Motion- write input file’ is closed to new replies.
4683
1565
1386
1242
