March 15, 2021 at 6:32 am
amdansys
SubscriberHi all!nThis is new problem since last week.nAlthough status massage of ANSYS Motion Standalone Solver Manager is Complete, no result file with the extension .dfr can be found in any folder.nOther output files (.dfs, .disp, .msg, .out, .res, .sres, .ssc, .strain, .stress) are in the same folder as .dfsxml file, and there is no error massage in .msg file.nHope someone can figure this out! Thanks!!!nn -
April 22, 2021 at 3:56 pm
Devashish Sarkar
Ansys EmployeeHi!, nSorry about the late response but if you are still wondering...nWere the files generated using Ansys MOtion Preprocessor? If so, you might have missed exporting the DFR file from the preprocessor. Or, if you have done that, maybe those files were misplaced.nIf that is the case, simply generate the files again from the post.nRegards,nDevashishnn
- The topic ‘ANSYS Motion – No result file (.dfr)’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1241
1118
1015
