March 11, 2024 at 2:01 am
hongxiao.xiang
SubscriberHello all,
I'm facing the solving problem caused by the function.Â
The error message shows that here is a unknown marker pair in a function.
I have checked the function and the argument list, as shown below:
Argument 1&2 is the marker' name. I'm sure that they are right.
But in argument 3&4, they are splines containing x-y data. I'm not sure the quotating method is right in function and argument list.
Looking forward to your reply.
March 11, 2024 at 2:27 am
hongxiao.xiang
SubscriberÂ
 I have no idea about the spline quotating method:(.
March 12, 2024 at 3:46 pm
Ankush Choudhary
Ansys EmployeeHi Hongxiao,
Which Ansys version are you using?
March 14, 2024 at 5:51 am
March 14, 2024 at 3:57 pm
Ankush Choudhary
The first argument of the step function is an independent variable, which is generally time in most cases. However, you are taking the relative angular velocity in the first argument. The same is the case with the AKISPL spline function, which generally needs an independent variable in the first argument, like time. I also noticed that you didn't close the bracket for the second argument of the step function.
Please check out the information on functions in motion document and try to build simple functions first.
March 18, 2024 at 1:15 am
hongxiao.xiang
SubscriberHi Ankush,
Thanks for your reply.Â
You said in te fore reply is that the first argument of the STEP/AKISPL function is an independent varibale.Â
I have queried the preprocessor manual. The manual shows
E1 is the real or expression type. So I think velocity function(expression) is also suitable for this clarification.Â
Hope for your further views:)
March 19, 2024 at 3:08 am
Ankush Choudhary
Yes, the E1 argument represents the independent variable, and it can also be an expression. Generally, in dynamic analysis, time is an independent variable. However, you can also use expression; it completely depends on your requirements and what information you need. I have tested the below function, which is working fine.Please test the below function expression.
STEP(WZ(#1,#2),-1*126/180*PI,1,126/180*PI,-1)*(0.535*AKISPL(ABS(FZ(#1,#2)),0,#3,0))+AKISPL(SQRT(TX(#1,#2)*TX(#1,#2)+TY(#1,#2)*TY(#1,#2)),0,#4,0)+8.78
- The topic ‘Ansys Motion Function problem’ is closed to new replies.
4607
1510
1386
1209
