July 30, 2025 at 5:33 pm
Scott Ormiston
SubscriberIs it possible to get a two-sided hyperbolic node distribution in ANSYS Mesher.
I would like to be able to set an edge sizing and specify that distribution with a first spacing size on each end.
July 31, 2025 at 8:38 am
Petros
Ansys EmployeeIf you insert an Edge Sizing then in Advanced→Bias Type you can set it to have a two-sided hyperbolic node distribution. You can also set the appropriate Bias Factor based on the desired node spacing.
July 31, 2025 at 1:13 pm
Scott Ormiston
SubscriberThank you very much for your quick response. Do you mean that the Bias Type that looks like this:
is two-sided hyperbolic? Or is there another way to access the two-sided hyperbolic distribution?
Also, is there a way of specifically setting the first spacing amount. I will have no way of predicting the ratio of smallest to largest spacings (what I think
Bias refers to). Is it supposed to be trial and error? If so, how to I determine the first spacing size easily?
Thanks.
August 1, 2025 at 11:46 am
Petros
Ansys EmployeeYes that is a 2-sided hyperbolic bias. If this is a wall and you want accurate modeling of the first spacing, maybe using the Inflation (RMB Mesh→Insert→Inflation) option is a better approach. This has the capability to specify First Layer Thickness.
3572
1178
1075
1063
952
