Ansys Mechanical Unlicensed Objects Opening in Read Only Mode
    • Jeremi Leasure
      My database at THIS LINK opens in read only mode after I changed the initial substeps from 2 to 5. I did not get the error when I changed the intial substeps at first. Only when I closed the model and re-opened it, then I received the message my database has unlicensed objects and it will be opened in read only mode.
      How do I take the database out of read only mode and how do I prevent this error from occuring in the future?
    • ashish.khemka
      Can you pleae share the snapshot of the model? Ansys employee cannot download the model but other forum members can chime in.
      Ashish Khemka
    • utp2
      Ciao a tutti. Ho acquistato Ansys Mechanical Pro e dopo averlo installato mi esce questo avviso, cosa fare? Devo prima disinstallare la versione 2022?
      La licenza sembre funzionare correttamente, però il file me lo apre in sola lettura
    • ashish.khemka
      Translated: Hi everyone. I purchased Ansys Mechanical Pro and after installing it I get this warning, what to do? Do I need to uninstall the 2022 version first?
      Ashish Khemka
  • The topic ‘Ansys Mechanical Unlicensed Objects Opening in Read Only Mode’ is closed to new replies.
