February 19, 2018 at 8:43 am
samsimulate
SubscriberHello,Â
I created a model in SpaceClaim and i got the error below after launching Ansys Mechanical.
''Update of the Model component in Steady-State Thermal failed: Mechanical failed to open the database: Unable to open file C:UsersAnalysis2D_Conduction_filesdp0globalMECHSYS.mechdb. Unable to get model.''
Can anyone help me to resolve this?
February 19, 2018 at 8:46 am
samsimulate
Subscriber -
February 19, 2018 at 9:19 am
Vishal Ganore
Ansys EmployeeHave you imported the geometry in Spaceclaim?
February 26, 2018 at 11:14 am
samsimulate
SubscriberI had to create the model again and try attaching several times - same process. It eventually attached but i never got to know why it didn't in the first place. Thanks @vganore.
August 31, 2019 at 11:14 am
baranakdag
Subscriber Hello. I have the same problem. I get the same error when I run the program. I created the object in spaceclaim. what is the solution?
August 31, 2019 at 1:46 pm
peteroznewman
SubscriberPlease insert a screen snapshot of the geometry in SpaceClaim. Make sure to show the Structure tab in the Outline. Is there a Surface or Solid body?
Also, next time, start a New Discussion so you will be informed of replies to your discussion.
January 31, 2022 at 6:46 am
January 31, 2022 at 6:47 am
April 19, 2022 at 3:04 am
YuJiali
Subscriber."Update failed for the Setup component in Transient Thermal.Unable to remove external enhanced model object in Mechanical.Unable to get model.Unable to remove external enhanced model object in Mechanical. Unable to get model.
How it was solved
- The topic ‘Ansys Mechanical Unable to get model’ is closed to new replies.
5159
1836
1387
1249
