October 16, 2024 at 9:00 pm
zS21002572
SubscriberHi
I'm trying to solve a mechanical problem with the 'static structural' tool of Workbench.
The mesh is OK and the values of pressure too, the problem appears when I click 'solve', it says: "An unknown error occurred during solution. Â Check the Solver Output on the Solution Information object for possible causes."
Does anyone know why? Do I need to give more information? I really need to solve this.
October 16, 2024 at 10:27 pm
peteroznewman
SubscriberUnder the Solution Information folder is Solution Output. Text will be shown that has detailed messages from the solver. Search the text (ctrl-F) for the word error and read the lines around that. Copy some of those lines and put them in your reply.
October 17, 2024 at 6:22 am
zS21002572
SubscriberIt's solved now. I just change the location of the file. It was inside 4 carpets and now it's just inside one, I supose Mechanical wasn't able to read the file because of where it was located.
Anyway, thank you mate! Have a nice day.
5939
1307
