October 27, 2024 at 12:23 pm
panjc
SubscriberI use the inistate command to simulate initial stress case.But the stress of the second step is different from the first.From the point of view of deformation, the direction is even thouh reversed.So,What is the reason for this situation?
October 28, 2024 at 5:23 am
Akshay Maniyar
Ansys EmployeeHi,
When using the INISTATE command to simulate initial stress, it's important to ensure that the initial conditions are correctly applied and that the subsequent analysis steps are properly linked. Can you share more details about the analysis you are doing and how you are using the INISTATE command?
Thanks,
Akshay Maniyar
Note: Just a reminder that you may use the Ansys Community Groups to develop your network and foster community by joining the appropriate group and making connections. If you are interested in structural analysis topics, please join the Structures community here: https://innovationspace.ansys.com/community/groups/?structures-community/.-
October 29, 2024 at 12:40 am
panjc
SubscriberThank you for your reply.I showed some pictures, help check what settings were wrong.
October 28, 2024 at 8:47 am
October 28, 2024 at 8:55 am
October 28, 2024 at 8:56 am
panjc
SubscriberThe settings are shown in the diagram above.
October 29, 2024 at 11:24 am
Akshay Maniyar
Ansys EmployeeÂ
Hi Panjc,
The commands look correct. Are you using the elastic material for the part?Â
Thanks,
Akshay Maniyar
October 30, 2024 at 12:36 am
panjc
SubscriberThe default material of the material library,structural Steel.It seems like just have elastic parameter.
October 30, 2024 at 12:51 am
October 30, 2024 at 12:57 am
October 30, 2024 at 1:00 am
October 30, 2024 at 5:21 am
Akshay Maniyar
Ansys EmployeeHi,
Stress will be imported for time 0 when you use INISTATE to import stresses. Therefore, the stresses returned to their initial state after the second model ran for one second. It is acting like a compressed spring at time zero and got uncompressed till time 1 second as there is no load acting on it.
Thanks,
Akshay Maniyar
November 4, 2024 at 7:43 am
panjc
SubscriberThank you for your reply.However,Is there any way to get the final stress of the previous step?and don't spring back.
November 6, 2024 at 4:33 pm
Akshay Maniyar
Ansys EmployeeHi,
You can fix both ends of the part and then import the stresses using INISTATE, so that the model won't regain and have the stresses.
Thanks,
Akshay Maniyar
5649
1885
1404
1303
