Ansys Mechanical encounter a problem when Mesh based connection is turned on
April 25, 2024 at 8:10 am
Cobus Janse van Rensburg
SubscriberAnsys Mechanical encounter a problem when Mesh based connection is turned on in Ansys 2024 R1.
Then Mechanical crash and close.
The model consists of 24 shell bodies.
A dump file is created.Can someone please help to explain why I get the error message when I switch on Mesh based connections in Batch connections under Mesh?
April 26, 2024 at 1:46 pm
Gary_S
Ansys EmployeeHello
If you look in Windows System Infomraiton > Error Reporting, you may see an Application Error with the following:Â
AnsysWBU.exe version 24.2023.331.1 Failure in module name FMTGKernel_WB.dll
If so, this is a known bug in 2024R1 having to do with licensing.
There will be is a 2024R1-SP3 available on the Customer Download portal no earlier than May 1.Â-
April 26, 2024 at 1:50 pm
SubscriberGary,Â
thank you very much for your reply, I appreciate it! I will watch out for the new service pack 3.
Regards
Cobus
- The topic ‘Ansys Mechanical encounter a problem when Mesh based connection is turned on’ is closed to new replies.
3155
1013
956
858
797
