February 24, 2022 at 6:49 pm
NCSU_Ansys
SubscriberSoftware crashes when trying to apply loads using the steps below
Preprocessor>Loads>Define Loads>Apply>Structural>Force/Moment>On Key Points> Select a point > apply
FX > Apply as Constant value >Value = 1 > apply
February 24, 2022 at 6:58 pmErKo
Ansys EmployeeUnfortunately this is an issue with the MAPDL UI in 2021 R2 - please use the F or FK command instead to apply load:
(/forum/discussion/32266/need-information)
so:
F,ALL,FX,1
applies a nodal load to all selected nodes in the x direction of 1 N.
or FK,1,FX,1
applies a load to keypoint 1 in the x direction of 1 N.
All the best
Erik
Viewing 1 reply thread- The topic ‘Ansys Mechanical APDL 2021 R2 crashes when applying load’ is closed to new replies.
5799
