Kampus Merdeka Belajar
Ask questions related to general and focused sessions.
Ansys Mechanical (Ansys License Manager Error: Not enough HPC Parallel Licenses)
    • akmalmahfuzh23
      How to solve this problem, after running simulation/ solve getting a notification to install then canceling and getting an error, what should I do to fix this problem? HELP!
    • George Karnos
      If you are running the free academic Student version, you can only specify a maximun of 4 cores.
      Looks like you set it to use 6 cores.
      Change to 4 and it should run.
    • Latanya Parks
      I think we should reduce the number of cores (processors) used for the simulation. For example, set the core usage to 4 instead of 8.
      To do this: Go to the Analysis Options or Solver Settings.
      Adjust the core count to a lower value (e.g., 4 cores).
      Save the settings and re-run the simulation24. geometry dash lite
  • The topic ‘Ansys Mechanical (Ansys License Manager Error: Not enough HPC Parallel Licenses)’ is closed to new replies.
