February 12, 2023 at 10:43 am
Victor
SubscriberHello,
I have been using Ansys Maxwell Student for a short time. I don't know if this is the right place to ask questions. I am trying to model two coils in mutual inductance. I followed exactly all the steps in this video: https://www.youtube.com/watch?v=L_Wa5prjPMk . However, when I get to the 'Analyze all' step, the analysis starts but stops a few minutes later and returns the message: [error] Setup1: Mesh size (75818 volume elements) exceeded Ansys Electronics Desktop Student limit. I understand that the student software is limited in performance. However, the simulation I'm asking for doesn't seem very complex to me, and I can't figure out how to solve this problem. I don't know where can I change the volume of the elements. So I would like to know how could I simulate this system with Ansys Student and its limitations. Waiting for someone's help.
Cordially, Victor
February 15, 2023 at 5:16 am
Chinmay T
Forum ModeratorHello,
In the initial mesh settings dialog box, keep the slider at a coarse resolution under the curved surface mesh setting and run the simulation.
Please check the mesh element count limit and product restrictions available on the AEDT Student download page:
https://www.ansys.com/en-in/academic/students/ansys-electronics-desktop-student
- The topic ‘Ansys Maxwell Student Mesh Limit’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3907
1414
1256
1118
1015
