July 2, 2024 at 7:45 pm
agyepes
SubscriberHello,
How does Maxwell handle mesh operations in case several mesh operations are defined simultaneously for a certain geometrical component? Does it try to fulfill all of them at the same time, just the least restrictive one, or something else?
Thank you.
July 9, 2024 at 6:28 pm
HDLI
Ansys EmployeeHello Alejandro Gómez Yepes,
   Maxwell has several different type mesh operations, like inside selection, on selection, skin depth, etc. When having different the mesh types for one object, Maxwell will apply all the mesh operations.
   When using the same mesh type like two "inside selection" for one object, Maxwell will only use the one with smaller element size and ignore another one.
HDLI
July 11, 2024 at 12:01 pm
agyepes
SubscriberThank you very much for your helpful response.
- The topic ‘Ansys Maxwell – Multiple mesh operations for the same component’ is closed to new replies.
6179
