October 5, 2023 at 9:24 pm
Hamid R
SubscriberHi everyone,
How can I download the database of electrical steel and magnet materials from the Ansys Maxwell material library? For example, Altair Flux material manager has most of the electrical steel and magnet materials, and it is available to export data to a Python file. However, I cannot import the data into the Maxwell material library.
October 6, 2023 at 7:01 pm
DELI
Ansys EmployeeHi, you can "export to library" in material "Select Definition" window, the file type is .amat( Ansys Material Library) not Python. -
October 7, 2023 at 6:29 am
Hamid R
SubscriberThank you for your answer. Is there any way to download materials for electric machines and import them into maxwell material library?
October 10, 2023 at 1:04 pm
DELI
Ansys EmployeeUsers can add their own material database to Personal or User library directories
- The topic ‘Ansys Maxwell material library’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1221
1118
1015
