Electronics
Electronics
Ansys Maxwell – InnerRegion and OuterRegion
    • agyepes
      When I generate a Maxwell 2D or 3D model of a rotating electric machine based on an RMxprt model, I see that a InnerRegion and OuterRegion bodies are automatically created. What are they for?
      Thank you.
    • GLUO
      The outer reigion is the solution region. The inner region is inside the motion band, and it includes all moving objects. If there is current inside the moving object, a inner band is necessary.
      GL
    • agyepes
      Thank you.
  • The topic ‘Ansys Maxwell – InnerRegion and OuterRegion’ is closed to new replies.
