TAGGED: -Ansys-Maxwell-electronics, error, maxwell, mesh, online-course, transient
February 1, 2024 at 8:20 am
blaz.starc
SubscriberHi,
I am trying to follow the course Ansys Maxwell Getting Started: Magnetic Transient.Â
When I use the file attached (Maxw_GS_2DmagTrans1) and follow the steps from the course, I get an error: "Surface Mesh Generation Failed". I originally thought I made a mistake, but when I ran the (Maxw_GS_2DmagTrans2), which has the complete first step done, I got the same error.
Could anyone suggest, how to solve that?Â
Thank you in advance.
February 1, 2024 at 4:07 pm
NA
Ansys EmployeeHello,Â
Could you kindly inform us which version of the software you are using? This issue has been spotted on the '23 versions and '24 versions and it is due to the geometry kernel change used by the software in these versions compared to the earlier ones. Basically, the moving region should not include hollow objects in it. So in this case, since you have a rotor with vacuum in the middle, the mesh generation has problems. The easiest way to solve it (and best practice for projects with rotational motion) is to include a shaft. So basically in this 2D model create a "circle" object with a radius of 25.4mm (as big as the hole in the middle of the rotor). This object should not be vacuum or air. Try the same material as the rotor. The results will be a bit different, but the model should work correctly. The workshop is in the process of being updated.Â
Kind regards,Â
N.A.
- The topic ‘Ansys Maxwell Getting Started: Magnetic Transient – failed mesh generation’ is closed to new replies.
4858
1587
1386
1242
