TAGGED: -Ansys-Maxwell-electronics, Dielectric, electricfield, voltage
May 12, 2025 at 8:54 am
lucie.barbeau
SubscriberHello,
I would like to know the calculation methods for the magnitude of the electrical field and the voltage along a line.
In my situation, I want to know the field in each part of my insulation system, but I also need to know what/how the distance is taken into account in the electric field, and if could change it.
Thank you for the help
May 12, 2025 at 11:36 am
Ivonne Marti
Ansys EmployeeHi Lucie,
You can plot a fields quantity (Mag_E, Voltage ...) along a line following these steps:
1/ Go to Maxwell 3D/ Results/ Create Fields Plot/ Rectangular Plot
2/ In the field “Geometry” select the line and in “Points” select the number of points that define your line (the default number is 101)
3/ In the field “Category” select “Calculator Expressions”
4/ In the field “Quantity” select “Mag_E” to plot the electric field magnitude or the desired quantity
4/ Select “New Report”
3044
971
879
858
792
