June 11, 2020 at 12:41 pm
congmin
SubscriberThe heat generated by maxwell is opposite to the temperature distribution curve
strange
.jpg?width=690&upscale=false)
Going out specific heat capacity convection conditions and other issues, making them contrary, is it possible that I have made a mistake in setting the conditions in the steady state thermal module operation
If so, can you tell me, what are the possible conditions?
Thanks -
June 17, 2020 at 7:20 pm
Karthik Remella
AdministratorThis question has been answered in a different thread. Here is the link.
/forum/forums/topic/maxwell-and-steady-state-thermal-2/
Best,
Karthik
June 29, 2020 at 8:13 am
congmin
SubscriberIn the steady-state thermal module, the result is that the workpiece is heated to about 600 degrees. I then went to the transient thermal module to analyze and found that after 600 degrees, the workpiece still heats up. Where does the problem cause this?
July 11, 2020 at 6:19 pm
July 23, 2020 at 12:52 pm
congmin
Subscriberhi Kreemella
I have new question about Steady state thermal,can you this link see and answer
/forum/forums/topic/maxwel-loss-imported-value-to-steady-state-thermal/
thank you
congmin
Viewing 4 reply threads
- The topic ‘Ansys Maxwell and steady state thermal’ is closed to new replies.
1582
1386
1242
