January 30, 2024 at 10:21 am
January 31, 2024 at 3:14 pm
Reshmi Raghavan
Ansys EmployeeHello Qiang,
Could you please let me know at what stage you are getting this error message?
January 31, 2024 at 3:20 pm
qiang wei
SubscriberI think the simulation was almost done (about 3-4 hours after started).
Then the results automatically genetated, during this process, the error occured.
February 1, 2024 at 4:20 am
Reshmi Raghavan
If the simulation was completed and the error occurred during the result extraction, you can retrieve the results by going back to the Machine design toolkit ACT . Provide the same set of inputs used for the analysis and at the last step you can find an option to use the simulated results to extract the output, please choose the given option.
February 1, 2024 at 11:08 am
qiang wei
SubscriberI did tick this option before the simulation started, I just confused why there are some many results generated automatically like the second figure I posted before? And I cannot stop it. Is this a compulsory process for the map simulation?
February 5, 2024 at 10:40 am
Reshmi Raghavan
Please enable the first option initially so that the initial angle prediction would be completed and the model with the parametric setup would be created.
Solve the parametric set up.
Upon completion of the parametric run , open MDT and come to the last page and select the option of "Use results of simulation to create efficiency maps". This would enable the tool to fetch the data from the previous run the plot the required results.
In a case where the result extractin doesnt proceed as expected the toolkit plots the results of all the quantities which are computed. Thats the reason why you are finding these plots added to the output. Upon succefful completion of the simulation these results would be replaced with the MDT output quantities like TvsSpeedvs Effeciency/Output power/Id/Iq etc.
- The topic ‘Ansys maxwell ACT machine toolkit ERROR’ is closed to new replies.
