July 9, 2020 at 2:47 pm
AnthonyPham
SubscriberDear Community,
please see the attached vector plot (YZ-plane) of the B-field generated by a thin solenoid excited with a steady current within a vacuum region. I am satisfied with the plot except for the asymmetrical display of the very high values at the end of the solenoid represented by the bigger arrows of red (top) and yellow (bottom) colour.
Is it possible to exclude these arrows/values such that the plot looks more homogenous and symmetric about the z-axis?
I tried the 'Magnitude Filtering' option, but it seems to only be able to filter out small values, not high ones.
Any help would be appreciated, thank you!
July 17, 2020 at 2:23 am
icellb
SubscriberHi,
I think your symmetric object simulation should not result in high B-field in one or two small spots. Maybe you should refine your mesh and simulate again. If that still doesn't work, maybe you could enlarge the spacing between the arrows hopefully the plotting will skip the red and yellow arrow.
December 3, 2021 at 7:13 am
Vanan
Subscriber.Hi,
I have a question about the surface plot.
I want to develop 3D surface plot and C-scan image in Ansys maxwell software. Can you help me regarding this?
Thanks in advance!
- The topic ‘Ansys Maxwell 3D Post-Processing – Can I exclude very high values in my plots?’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4387
1494
1375
1203
