Electronics
Electronics
ANSYS Maxwell
    • Escobar8
      Does free student software include ANSYS maxwell of Electromagnetics kit?
      No, it does not include Maxwell, but it does include the Magnetostatic system analysis.
    • AKWorld
      How can I download ANSYS maxwell please?
    • Mark Christini
      You need to contact ANSYS sales dept to get copy of Maxwell.
    • rishabh1234
      Hello community,nI want to know that how can I import my Maxwell geometry into workbenchn
    • NKC
      Hi @rishabh1234nStart workbenchnFile>ImportnChange the file type to ANSYS Electronics Desktop Project File (*. aedt ).nBrowse to the file and open it.nnBest RegardsnNavyan
    • GOANUP
      do any one know how to learn Maxwell 3D step by step. Means any tutorial ??n
    • NKC
      nOpen Maxwell > Go to help > Maxwell pdfs> Maxwell getting started guidesnHere you will find some tutorial guides.nAlso, look in the Maxwell help document for more details.nnRegards,nNavyan
    • Robert Krobot
    • kaushal.singara.chari
      I am trying find the voltage induced in a rogowski coil due to a given alternating current. My analysis gets validated by the computation time is too long and I get some error related to "server" in the end. I am attaching an image of my analysis. Can somebody tell me what's worng with my model?
      my model
    • Hasan Safi
      Hello, i have two questions;
      1. I gave a 300v sinusoidal voltage to the primary winding of my high frequency transformer but when I checked the graph after simulation it was not a sinusoidal wave, can you please help me find the problem? You can find the equation and the results attache
      2. Can you please give me the equation for sqaure waveform with 300v magnitude, 50% duty cycle and 20kHz frequency?
      I have run a magnetic transient analysis on ansys maxwell 3d to find the voltage induced in the rogowski coil for a given alternating current. My maximum value of induced voltage after analysing it in ansys maxwell is 5.3 mV. The same value based on a given analytical formula is around 5.6 mV. I have run my analysis with the default mesh settings. Can someone tell me what I should change in my mesh to get more accurate result? Also the goal of my analysis is to estimate the error induced due to a gap at one end of the coil, when the primary conductor is not in the centre of the coil. I ran another analysis with the primary conductor closer to the gap and I got an induced voltage of around 5.2 mV. The mesh settings for both analysis are exactly same. Is it safe to assume that the relative error i.e, 0.1/5.3 is unaffected by the error induced due to the finite element method. I have attached an image of my analysis below.my geometry
    • GLUO
      Hello all,
      Please post your question in new individual threads or use the suppot button at left to submit a support ticket to have an engineer help you.
      Thanks,
      GL
    • elad kadosh
      Hello ,
      i wish to create a simulation of displacement current, changing elecrtric field creating a magnetic field.
      in the Ansys Electronics desktop (student version) there is only a magnetic solution or electric solution (not both at the same time), where displacement current creates a magnetic field as a product of electric field so i need both solvers at the same time. I understant that in the Workbench it is possible to do such a thing, i downloaded Workbench and trying to figure out how to do it but with no success, can you please help me with how to do it ?
      Thanks,
      Elad.
Viewing 13 reply threads
  • The topic ‘ANSYS Maxwell’ is closed to new replies.
