February 21, 2023 at 2:45 am
February 27, 2023 at 2:01 pm
Ram Gopisetti
Ansys EmployeeHi we (ANSYS) support xml file, so if you could check the xml file of sample libray you can parse the database into our xml format.Â
Cheers, RamÂ
February 27, 2023 at 7:15 pm
mrife
Ansys EmployeeHi Henri
In the lower right of the UI you posted is a 'Export to Library' option. You can create your materials then export them to a library. Then next time it will show up as a personal library in the upper right (if saved to your personal location). Â
Ram & Henri - Maxwell uses a library format similar to XML but is not XML. Â
- The topic ‘ANSYS Materials Library’ is closed to new replies.
1587
1386
1242
