November 22, 2018 at 4:20 pm
sanju111
Subscriberi drew an 3d line diagram in solidworks is there any way i can convert into fe model with bar element in mechanical apdl
November 22, 2018 at 4:54 pm
Sandeep Medikonda
Ansys EmployeeHi Yes, you should be able to do that. Look in the help here on how you can bring in Solid Works files. Also, check out the tutorial specified in this discussion.
Sandeep
Guidelines on the Student Community -
November 24, 2018 at 5:09 pm
November 24, 2018 at 8:48 pm
jj77
SubscriberDefine a 3D truss element (LINK180), define section area (real constants), material properties, mesh the lines, apply restraints, and loads, define the type of analysis and solve. Many tutorials on the internet on how to model truss structure.
Be aware: for every member/line segment use only one truss element (if you use many it becomes a chain which is unstable). So one truss element per member.
- The topic ‘ansys mapdl’ is closed to new replies.
3572
1188
1076
1063
952
