May 26, 2025 at 2:50 am
1617836513
SubscriberWhat are the criteria for element failure in this material model? If one of the pictures 1 or 2 is satisfied, will the element be deleted? Or do need to meet both criteria at the same time? Is the deletion of the element only related to the stress strength and ERODS entered in the material card? But ERODS is evaluated against a scalar strain computed from the two in-plane normal strains and the in-plane shear strain. Suppose I enter an ERODS of 0.5, will the unit be deleted when the ERODS value calculated by the formula in Figure 3 reaches 0.5?
June 3, 2025 at 2:10 pm
Ashish Khemka
Forum ModeratorHello, same query is asked here: Ansys Ls-prepost Material Mat-58 element failed critical | Ansys Learning Forum
I will close this one.
Ashish Khemka
- The topic ‘Ansys Ls-prepost Material Mat-58 element failed critical’ is closed to new replies.
3190
1024
962
858
798
