April 25, 2024 at 5:08 am
adalberto.salazar
SubscriberHi,
I´m using Chemkin-pro with the free student software, but I am experiencing some problems with the license of 2024 R1.
Currently, when I open the program a license is assigned to me, but when I run a simulation even examples I receive this message from the .out:
ÂERROR: could not get a license
Flexlm error report:ÂÂNo FlexNet Publisher (FNP) license found for feature HPC Parallel.      FNP license path: C:\Users\adalb\AppData\Local\Temp\\413bcf9d-e62e-4403-8145-b38af90de186No such feature exists.PREMIX: Error initializing gas-phase
April 25, 2024 at 11:06 am
Rajeshwari Jadhav
Forum ModeratorHi Adalberto,
How many cores are you using? student version supports only 4 cores.
April 25, 2024 at 4:24 pm
adalberto.salazar
SubscriberHi,
I'm using 4, but the problem shows even when im using 1 core.
Not even the examples can be resolved.Â
April 26, 2024 at 11:59 am
Rajeshwari Jadhav
in your start menu type %appdata% to delete/rename Ansys folder to Ansys.old and %temp% to rename .ansys to .ansys.old. Launch the application with 1 cores without any examples first.
June 2, 2024 at 3:16 am
chinazyq
SubscriberANS_LogErrorMessage: Caption: ANSYS LICENSE MANAGER ERROR Â Error: No FlexNet Publisher (FNP) license found for feature HPC Parallel.
I also met the similar problem when I use chemkin. I don't know why. -
June 2, 2024 at 3:33 am
chinazyq
SubscriberHow to change core number?
- The topic ‘Ansys Licence 2024 R1 Problem’ is closed to new replies.
6144
