October 20, 2020 at 3:38 am
liwei
SubscriberI am trying to install ANSYS on a HPC cluster that has been configured with CentOS 8.0. I was not able to install ANSYS 2020 R2 and it seems the supported platforms are up to CentOS 7.7. nIs there a way that I can walk by this requirement and install ANSYS (in particular, FLUENT and Chemkin-Pro)on this cluster? Thank you very much.n n -
October 20, 2020 at 8:52 am
Forum ModeratorAccording to Platform Support https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support we will probably support 8.1 with 2021R1. I think there's a fix on the OS side to replace some missing libraries, but it's not technically supported (ie we've not tested it): note, in my role I break computers, Array and out IT team gets the fun job of fixing them.....
October 20, 2020 at 8:51 pm
ANSYS_MMadore
Forum ModeratorWe currently do not have any documented fixes for CentOS 8.0. Customers may have found their way through library issues, but it is unsupported. Installation on CentOS 8.0 has been a known problem.
October 22, 2020 at 2:32 am
liwei
SubscriberI see. Thank you.
October 22, 2020 at 3:12 am
liwei
SubscriberI am trying to find the ANSYS Installation Guide. Can you share me the links/documents if there are any so I can review the library requirements? Thank you.
October 22, 2020 at 10:30 am
Forum ModeratorThere's some information here https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support otherwise I think the installation stuff is in with the download, or accessible from the same location.
November 29, 2020 at 9:12 pm
liwei
SubscriberThanks for the help on a follow-up question. After the installation of ANSYS on the HPC cluster, how should I set up the license information?
For example, FLUENT executable is located in "/shared/ansys_inc/2020_R2/v202/fluent/bin". Our license server is
ANSYSLI_SERVERS: 2325@OurLicenseServerID
FLEXlm Servers: 1055@OurLicenseServerID
Can I set up the license by adding the following lines to "~/.bashrc"? Any comments and corrections are welcome. Thank you.
export NTI_LICENSE_FILE=2325@OurLicenseServerID
export PATH=/shared/ansys_inc/2020_R2/v202/fluent/bin:$PATH
November 30, 2020 at 3:50 pm
December 1, 2020 at 3:27 pm
ANSYS_MMadore
Forum ModeratorArray Are you trying to run the FLUENT UI over this connection? Do you have Qt installed as that is a required 3rd party install that requires 777 permissions. You may need IT to help with obtaining this if you don't currently have it on the systems.
Thanks
Matt
December 2, 2020 at 3:18 am
liwei
SubscriberArray Qt is installed. Can you take a look at the attachment in the previous post? I showed all details. Also, can you help me with the license server connection? Thank you.
December 2, 2020 at 1:49 pm
ANSYS_MMadore
Forum ModeratorArray Can you send the current setting of your LD_LIBRARY_PATH? Perhaps you can try:
export LD_LIBRARY_PATH=/shared/ansys_inc/2020_R2/v202/tp/qt/5.9.6/linx64/lib/libQt5Quick.so.5:$LD_LIBRARY_PATH && fluent
For licensing, set ANSYSLMD_LICENSE_FILE=1055@LicenseServerHostname and ANSYSLI_SERVERS=2325@LicenseServerHostname
Thank you,
Matt
December 2, 2020 at 3:44 pm
December 2, 2020 at 5:36 pm
December 2, 2020 at 6:02 pm
ANSYS_MMadore
Forum ModeratorCan you try setting this to see if it helps?
setenv QT_XCB_NO_XI2 1
or
export QT_XCB_NO_XI2=1
Thanks,
Matt
December 2, 2020 at 8:58 pm
December 2, 2020 at 9:06 pm
ANSYS_MMadore
Forum ModeratorJust to confirm, is this a viz node you're trying to run on?
December 3, 2020 at 5:09 pm
liwei
SubscriberI am not sure what is "a viz node".
I am trying to run FLUENT on a HPC cluster. This cluster has the OS of Centos 8.0 and additional libraries of Centos 7.0.
I am connecting to the cluster from my local Windows PC via PuTTY + Xming.
December 3, 2020 at 5:23 pm
ANSYS_MMadore
Forum Moderator"viz node" is a machine with graphic display and designated graphics card, rather than only a command line system.
December 3, 2020 at 5:24 pm
ANSYS_MMadore
Forum ModeratorPlease note, we do not support Xming for use with remote display. Please see this site for supported remote display environments.
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/remote-display-and-virtual-desktop-support-2020-r2.pdf?la=en&hash=3DFEC2C3DA61AFD9F8657FE97447A20C16580C72
December 4, 2020 at 5:56 am
liwei
SubscriberThank you, Matt.
Is this a new requirement? Two years ago, I used to (from a Windows machine) remotely run FLUENT on a HPC with the graphic interface. I recall it only involved some X-window forwarding option. But at that time I was a user and didn't know about the HPC system settings. Now that I am trying to set the HPC and more/different requirements may be needed.
Can you give me some instruction on the software installation/preparation, both for the local Windows machines and the remote HPC cluster? I'd like to (from a Windows machine) remotely run FLUENT on the cluster with the graphic interface. Thanks.
December 4, 2020 at 1:02 pm
ANSYS_MMadore
Forum ModeratorArray It is not new, it was never officially supported though may have worked with older releases. Newer releases are more sensitive to graphics requirements, tested and supported to run on the setups from the shared link.
If you have access to the Customer Portal there are KMs posted available on using RSM to run a FLUENT solve from your Windows machine to solve on a remote Linux cluster.
December 4, 2020 at 11:13 pm
liwei
SubscriberThanks, Matt. I checked the RSM, but am still interested in Remote Display & Virtual Desktop.
For Device "VNC Connect 6.7 with VirtualGL 2.6", how should I configure the CentOS cluster and the local Windows computer? Thanks.
December 7, 2020 at 12:34 pm
ANSYS_MMadore
Forum ModeratorArray You'll need to follow instructions available with VNC on the installation and configuration.
December 7, 2020 at 4:50 pm
liwei
SubscriberArray Can you elaborate which "instructions available with VNC on the installation and configuration"? I did find the instruction for VNC installation, but how should I configure it for ANSYS environment? What are the other configurations needed to set up the Virtual Desktop for ANSYS?
There is little information in ANSYS INC Installation Guides and if not with your help, I wouldn't have the document of Support for Remote Display & Virtual Desktop. Can you give me the guidance with more details? Thank you.
December 7, 2020 at 4:55 pm
ANSYS_MMadore
Forum ModeratorArray You need to install and run VNC Connect 6.7 at minimum. Install this as instructed by VNC Installation documentation for your Windows / Linux configuration. You also need to install VirtualGL 2.6. This is an installation entirely separate from ANSYS. If you have it installed and running, you should be able to have a remote desktop environment from the Linux side displayed on your Windows machine through the VNC window. That's where you would be able to run ANSYS. There must also be supported graphics devices on the Linux machine you'll be connecting to.
December 26, 2020 at 11:05 pm
liwei
Subscriber.mmadore I was not able to set up a virtual machine, so I am trying to run it in batch mode.
I tested the command "fluent 2d -g -t8 -i journalfile.jou out.out", and got the attached error messages "BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES", even I only used one core (-t1). Could you give me some help? Thank you.
December 30, 2020 at 2:21 pm
ANSYS_MMadore
Forum ModeratorArray Can you please post the contents of the files you've shared? We are not able to download files from the forum.
January 4, 2021 at 3:37 pm
liwei
SubscriberArray Here are the error messages. Thanks for any comments and recommendation.
"/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/bin/fluent ‐r20.2.0 2d ‐pshmem
‐host ‐t1 ‐mpi=intel ‐path/shared/ansys_inc/2020_R2/v202/fluent ‐ssh ‐cx
apollo:39917:37665
Starting
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/lnamd64/2d_host/fluent.20.2.0
host ‐cx apollo:39917:37665 "(list (rpsetvar (QUOTE parallel/function) "fluent 2d
‐flux ‐node ‐r20.2.0 ‐t1 ‐pshmem ‐mpi=intel ‐ssh") (rpsetvar (QUOTE parallel/rhost)
"") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string)
"1") (rpsetvar (QUOTE parallel/auto‐spawn?) #t) (rpsetvar (QUOTE
parallel/trace‐level) 0) (rpsetvar (QUOTE parallel/remote‐shell) 1) (rpsetvar
(QUOTE parallel/path) "/shared/ansys_inc/2020_R2/v202/fluent") (rpsetvar (QUOTE
parallel/hostsfile) "") )"
Welcome to ANSYS Fluent 2020 R2
Copyright 1987‐2020 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re‐export.
For full Legal Notice, see documentation.
Build Time: May 29 2020 10:12:26 EDT Build Id: 10176
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "apollo" (unix).
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/bin/fluent ‐r20.2.0 2d ‐flux
‐node ‐t1 ‐pshmem ‐mpi=intel ‐ssh ‐mport 172.16.100.1:172.16.100.1:37775:0
Starting
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/multiport/mpi/lnamd64/intel/bin/
mpirun ‐‐rsh=ssh ‐f /tmp/fluent‐appfile.root.937448 ‐genv FLUENT_ARCH lnamd64 ‐genv
I_MPI_DEBUG 0 ‐genv I_MPI_PIN disable ‐genv I_MPI_ADJUST_REDUCE 2 ‐genv
I_MPI_ADJUST_ALLREDUCE 2 ‐genv I_MPI_ADJUST_BCAST 1 ‐genv I_MPI_ADJUST_BARRIER 2
‐genv I_MPI_ADJUST_ALLGATHER 2 ‐genv I_MPI_ADJUST_GATHER 2 ‐genv
I_MPI_ADJUST_ALLTOALL 1 ‐genv I_MPI_ADJUST_SCATTER 2 ‐genv I_MPI_PLATFORM auto
‐genv PYTHONHOME
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/../../commonfiles/CPython/3_7/li
nx64/Release/python ‐genv FLUENT_PROD_DIR
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0 ‐genv KMP_AFFINITY disabled
‐genv TMI_CONFIG
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/multiport/mpi/lnamd64/intel/etc/
tmi.conf ‐n 1 ‐host apollo
/shared/ansys_inc/2020_R2/v202/fluent/fluent20.2.0/lnamd64/2d_node/fluent_mpi.20.2.
0 node ‐mpiw intel ‐pic shmem ‐mport 172.16.100.1:172.16.100.1:37775:0
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= PID 937491 RUNNING AT apollo
= EXIT CODE: 1
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
= EXIT CODE: 1
Intel(R) MPI Library troubleshooting guide:
https://software.intel.com/node/561764
Client interrupted.
Done.
| ANSYS Product Improvement |
| ANSYS Product Improvement Program helps improve ANSYS |
| products. Participating in this program is like filling out a |
| survey. Without interrupting your work, the software reports |
| anonymous usage information such as errors, machine and |
| solver statistics, features used, etc. to ANSYS. We never |
| use the data to identify or contact you. |
| The data does NOT contain: |
| ‐ Any personally identifiable information including names, |
| IP addresses, file names, part names, etc. |
| ‐ Any information about your geometry or design specific |
| inputs. |
| You can stop participation at any time. To change your |
| selection go to Help >> ANSYS Product Improvement Program |
| in the GUI. |
| For more information about the ANSYS Privacy Policy, please |
| check: http://www.ansys.com/privacy |
999999: MPT_csend_int: error: file = ../../src/mpcommun.c, line = 1467: mpid = 0
undefined: Resource temporarily unavailable
999999: MPT_crecv_int: error: file = ../../src/mpcommun.c, line = 1467: mpid = 0
Reading journal file journalfile.jou...
> /file/read‐case D5L10_tube_5umGrid.cas
Error: read‐case: invalid machine
Error Object: #f
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
> exit
undefined: Resource temporarily unavailable "
January 4, 2021 at 4:51 pm
ANSYS_MMadore
Forum ModeratorArray Are you still running CentOS 8? Please note that this is unsupported and prone to problems. You can try adding mpi=openmpi to your command and see if that helps.
February 24, 2021 at 3:23 pm
WilliamWilson
SubscriberWe are having the same problem on Centos 8.2. We get the following error:
/packages/ansys/21r1/v211/licensingclient/linx64/ansyscl: symbol lookup error: /lib64/libk5crypto.so.3: undefined symbol: EVP_KDF_ctrl, version OPENSSL_1_1_1b
We have the following rpms installed:
openssl.x86_64 1:1.1.1g-12.el8_3
krb5-libs.x86_64 1.18.2-5.el8
We're an academic institution.
February 26, 2021 at 5:32 pm
ANSYS_MMadore
Forum ModeratorArray have you confirmed all prerequisites have been installed?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_sysprereqs.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_addlhwswreqt.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_thirdparty.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platformdetails.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platform_libraries.html
March 5, 2021 at 9:30 am
WilliamWilson
SubscriberMuch further on the install. The support document indicates Centos 8.1 good for Ansys and specifically Fluent. At the end of the install, we have some errors. Any clue on how to fix them?
ANSYS installation: Thu Mar 4 11:26:04 2021
Revision: 2021 R1
ERROR: /usr/ansys_inc/v211/aisol/.workbench -cmd /usr/ansys_inc/v211/aisol/../commonfiles/MainWin/linx64/mw/bin-amd64_linux_optimized/regsvr32 -c -nodisplay /usr/ans
ys_inc/v211/aisol/dll/linx64/libans.graphics.graphutilityu.so failed
ys_inc/v211/aisol/dll/linx64/libans.cadint.configmgrcom.so failed
/usr/ansys_inc/v211/CFX/bin/../tools/perl-5.28.2/bin/perl: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
###### Error #######
Error executing configuration script '/usr/ansys_inc/v211/commonfiles/configs/linx64/config/AnsConfigCFX.sh'
'"/usr/ansys_inc/v211/commonfiles/configs/linx64/config/AnsConfigCFX.sh" -installdir "/usr/ansys_inc" -rev 211 -dotrev 2021 R1 -scripttosource "/usr/ansys_inc/v211/co
mmonfiles/configs/linx64/config/ConfigCommon.tcl" -sourcedir "/tmp/ans_install_tmp2569060" -os_lang en-us -install -skip_file_associations ' terminated after 1 attempts w
ith the following error(s):
Unknown error
Exit Code: 127
With that, trying to run runwb2 just to test, we get:
Unhandled exception caught :
System.DllNotFoundException: Ans.QT.dll
at Ansys.UI.Toolkit.QT.Application.SetPluginDirectory () [0x000f2] in :0
at Ansys.UI.Toolkit.QT.Application..ctor () [0x00006] in :0
at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in :0
at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000f] in :0
at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in :0
at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in :0
--- System.TypeInitializationException: The type initializer for 'Ansys.UI.Toolkit.Application' threw an exception.
at Ansys.UI.UIManager..ctor () [0x00060] in :0
at Ansys.UI.UIManager.get_Instance () [0x00029] in :0
at Ans.Program.Runtime.InitializeSplashScreen () [0x00060] in :0
at Ans.Program.Runtime.Initialize (Ans.Program.RuntimeSettings settings) [0x00237] in :0
at Ans.Program.ExecutableBase.Run (Ans.Program.CommandLineParse parser) [0x0000d] in :0
at Ans.Program.ExecutableBase.DoMain (System.String[] args) [0x000cf] in :0
May 18, 2021 at 11:43 am
himanshubanait17
Subscriber.For "System.DllNotFoundException: Ans.QT.dll"
Please install "libpng12-0" on linux
sudo add-apt-repository ppa:linuxuprising/libpng12
sudo apt update
sudo apt install libpng12-0
March 23, 2022 at 6:28 pm
jchrisj
Subscriber.We are seeing the libk5crypto error on our version 8 systems but not on version 7
March 23, 2022 at 8:16 pm
ANSYS_MMadore
Forum Moderator.jchrisj Please search the forum for related threads. This is known for version 8 for Ansys releases which don't support 8.x.
- The topic ‘ANSYS Installation on CentOS 8.0’ is closed to new replies.
3597
1283
1117
1068
983
