March 10, 2021 at 12:14 pm
Greg Baethge
Ansys EmployeeThis topic describes the CW normalization used to convert time domain data to frequency (steady-state) data. The CW normalization option should be used whenever you collect frequency domain information.
Solvers: FDTD, varFDTD
See also:
Frequency domain normalization
Single frequency simulations in FDTD
Sources in FDTD always inject a pulse (i.e. broadband), even when the user is only interested in collecting data at a single frequency. Pulse sources are more efficient for collecting broadband information, and at least as efficient when collecting information at a single frequency. Therefore, there is no reason to use CW sources. The CW response of a structure can easily be obtained from a simulation that used a pulse source.
The following screenshot shows the source Frequency/Wavelength settings tab. In this screenshot, the source wavelength is set to a single frequency of 500nm. Even thought the frequency span is zero, a pulse is still used. The time domain signal of the pulse, and the associated power spectrum, are shown in the figures on the right side of the window.
When the source frequency span is set to zero (i.e. single frequency), then the frequency domain monitors will automatically mearure the response of the system at that frequency only.ÂCreating a CW sourceWhile we strongly recommend against using a CW source, it is possible to create them in FDTD. For example, it is possible to create a source time signal like the one shown below. For more information on creating custom source time signals, see the Creating a custom source time signal page.ÂÂYour data analysis may be more complicated when using a CW source. The frequency domain normalization will not work properly with a CW source. The CW normalization requires that the time domain fields decay to zero by the end of the simulation. -
October 18, 2023 at 12:36 pm
adevi
SubscriberÂ
Hi,Â
Can you kindly share with me the script for creating the CW source as shown in the second figure if its available?
With kind regards.
October 19, 2023 at 1:53 pm
adevi
SubscriberHi,
I found the discussion here very helpful : /forum/forums/topic/how-is-a-monochromatic-source-applied-in-time-domain-simulations-in-lumerical/. And, I have found the script in the following link: https://optics.ansys.com/hc/en-us/articles/360042192813.Â
With kind regards.
- The topic ‘Ansys Insight: Single frequency CW source’ is closed to new replies.
5694
1891
1419
