September 3, 2021 at 5:47 pm
Guilin Sun
Ansys Employee一般的计算机语言都有保留字符,它们具有特定的数值,用户最好不要用它们做变量名,Lumerical的Script也一样。常见的保留字符有 ·e:电荷1.60218e-019库仑 ?e; result: 1.60218e-019 ·h:普朗克常数6.62607e-034 J⋅s ?h; result: 6.62607e-034 ·hbar:Reduced Planck’s constant ?hbar; result: 1.05457e-034 ·c:真空中的光速 299792458 米每秒 ?c; result: 299792458 ·pi:圆周率 3.14159 ?pi; result: 3.14159 以上是使用短数据格式,如果使用长格式,则 format long; ?pi; result: 3.141592653589793还有其它很多英文字,例如三角函数和数学运算符号,以及下列单词:add, abs,all,any,angle,bar, break,cd, cell, clear, conj, connect, copy,cross,delete,dir,dot,erf,exist, exit,exp,expand, eye,fft,find, flip floor, for, format. get, global, grating, help, hide,histogram,if,image,insert,inv, legend, length, library,load, log, lower, is, matlab, matrix,max,min,mean, mesh,mold, move, new, norm,or, orbit, overlap, pause, pinch, plot, polar,precision,propagate, probe, pwd,rand, read, real,redo,refresh,replace,rm,round,run,save,select,set,show,sign,simulation, size,solar,spline,sqrt,system,transmission, transpose, try, undo, upper,version,visualize,which,write,zeros,等注意,上述禁词多数适用于每个产品,有的仅用于某个产品,例如INTERCONNECT。请注意查询,或者在设置变量是避免使用单个字母或者单个英语单词。自然对数的底e可以用下列方法得到 ?exp(1); result: 2.718281828459045 更多的脚本链接参见这个帖子: Ansys Insight: Lumerical脚本命令列表
Viewing 0 reply threads
- The topic ‘Ansys Insight: 脚本中的保留字符和英语单词’ is closed to new replies.
1306
