September 14, 2023 at 8:49 pm
jmcleod
SubscriberHello,
I am currently experiencing a critical issue when trying to run the Ansys 2023R2 ICEM-CFD program. We keep seeing an error stating, "OPENSSL_Uplink(00007FFD5A6A1820,08): no OPENSSL_Applink" the error is attached. Further, we have tried a complete uninstall and re-install and we have also tried on brand new machines. We consistently get this error for this version.
Interestingly, we have the Ansys 2020R2 ICEM-CFD version installed and we can launch this version with absolutely no issues. We have not tried versions from other years, only 2020 and 2023.
September 22, 2023 at 11:51 am
George Karnos
Ansys EmployeeHello Jeremy,
What Operating system are you trying to run on?
Have you checked that all the prerequisites are installed? -
September 22, 2023 at 3:51 pm
jmcleod
SubscriberWe have tried both windows 10 and windows 11. Yes, all pre-requisites are installed and seem to be functioning correctly.
October 11, 2023 at 12:06 pm
George Karnos
Apologies for the delay.
Cant you check for the following files:"C:\Windows\System32\libcrypto-1_1-x64.dll"
"C:\Windows\System32\libssl-1_1-x64.dll"
If they exist, please try renaming them to:"C:\Windows\System32\libcrypto-1_1-x64.dll.safe"
"C:\Windows\System32\libssl-1_1-x64.dll.safe"
Now try to run.
December 15, 2023 at 1:44 pm
neilb.mcfadyen
SubscriberHello
we are getting the same problem, however the files are not there to rename
December 15, 2023 at 1:47 pm
neilb.mcfadyen
Subscriberactually the error we get is
med.exe - system error
the code execution cannot proceed because libssl-1_1-x64.dll was not found. Reinstalling the program may fix this problem
we have installed Ansys 2023R2 and sp2
October 11, 2023 at 5:38 pm
jmcleod
SubscriberHello,
Thank you for that update! I gave it a try as both of those files did exist on the system. However, now the system goes into a "Not Responding" state and I get the following error. I checked our license server and I believe it is good to go and our license is supposed to cover PostPrep. Also, even though our server adresses are redacted in the image, I have double checked them to ensure accuracy and they are correct (plus our other Ansys products work).
October 11, 2023 at 7:07 pm
George Karnos
Ansys EmployeeThe Flexlm server not responding message is usally due to the ansyslmd daemon on the license server(s)
being blocked by the firewall on the license servers.
C:\Program Files\ANSYS Inc\Shared Files\licensing\winx64\ansyslmd.exe/ansys_inc/shared_files/licensing/linx64/ansyslmd
October 11, 2023 at 7:15 pm
jmcleod
SubscriberI agree! However, it was only ICEM that gave me that error. All of the other Ansys programs worked and found the license manager (including the licensing application which could test the server). This error only occured after changing those two files. Once I changed them back, we went back to the original SSL error.
October 11, 2023 at 7:22 pm
George Karnos
Ansys EmployeeUnder %TEMP%\.ansys\Â on the machine where you are trying to start ICEMCFD, you should see a file named:
licdebug.HOSTNAME.CONNECT.232.out
(Where hostname is the machine name)Check this file with notepad.
What are the errors in this file?
Also, there should exist another file:
ansyscl.hostname.#####.#####.log
Check this for errors,also. -
October 11, 2023 at 8:00 pm
jmcleod
SubscriberHello,
So, we figured out that there was an error on our license, but we got that straigtened out. I was able to go back to step 1 which was changing the file names and that resulted in ICEM working this time. We have many different users that use ICEM-CFD that would like to use this new version. Are we going to have to change the file names everywhere we install this product?
Best,
-Jeremy
October 11, 2023 at 8:04 pm
George Karnos
Ansys EmployeeThat is great!
Unfortunately, yes, those files will need to be renamed on any machine
running ICEM-CFD.
- The topic ‘Ansys ICEM-CFD Critical Issue’ is closed to new replies.
