Ansys Gateway powered by AWS – Express Setup Overview and Prerequisites
July 26, 2023 at 7:05 pm
Krishna Samavedam
Ansys Employee/ Introduction
To enable your company to access Amazon Web Services (AWS) resources via Ansys Gateway powered by AWS, you must complete a setup process. This is automatically launched on the screen when you subscribe to Ansys Gateway powered by AWS. There are two options available for setting up Ansys Gateway powered by AWS: Express and Manual. Ansys recommends Express setup as it requires minimal IT expertise and configuration. Manual setup is only needed if you want to integrate Active Directory with Ansys Gateway powered by AWS. To perform the setup, you must have an Ansys ID. For more information about Ansys ID see the Ansys Account Management guide or the Ansys Sign-In Help. Post onboarding, users can sign in to Ansys Gateway web portal if their Ansys ID email address domain matches the Ansys ID email address domain of the IT administrator, which is used during onboarding. However, users need to be explicitly added to Project Space/s to view or access any Project Space. To prepare for connecting to Ansys Gateway powered by AWS, ensure that you meet the prerequisites for your desired setup method.
This article refers to Express Setup, For Manual Setup
Please see: Ansys Gateway powered by AWS – Manual Setup Overview and Prerequisites
/ Overview of Express Setup Overview and Prerequisites
Please see this short video: Express Setup to get started with Ansys Gateway powered by AWS (vidyard.com)
/ How Ansys Gateway powered by AWS works
Here is an overview of how everything connects and works together.
/ Prerequisites
This setup process is configured for customers with a single domain only. If your email/authentication/Active Directory domains are different from your main company domain, please contact Ansys support. This guide assumes that you have the following already set up:
/ Prepare you AWS environment
To prepare for connecting to Ansys Gateway powered by AWS, you must have the following set up in AWS:
AWS Administrator who is running Express setup should have full administrative privileges to run AWS Cloud Formation Template (AWSCloudFormationFullAccess policy) on their AWS account. During Express setup, AWS Administrator will be asked to run an AWS Cloud Formation Template which provides a shared access role with the following policies to Ansys Gateway by AWS and a default VPC will be created in the selected region.
- AmazonEC2FullAccess
- ServiceQuotasFullAccess
- AWSPriceListServiceFullAccess
- AmazonVPCFullAccess (Required only for onboarding. This permission can be removed post onboarding)
- AWSCloudFormationFullAccess (Required only for onboarding. This permission can be removed post onboarding)
/ Post-Setup
/ Add additional VPCs (optional)
- If you want additional Virtual Private Clouds (VPCs) beyond the default VPC created by the setup, ensure that there is a VPC for each region in which you want to use Ansys Gateway powered by AWS.
A Virtual Private Cloud (VPC) is a pool of shared resources allocated within AWS Cloud. Each VPC is associated with a specific region. This determines the AWS data center that will provision the resources. Learn more about Amazon VPC.
Requirements for each VPC:
- From the VPC to the Internet:
- Port 443 outbound to enable communication to the Ansys Gateway powered by AWS Control Plane and the virtual machines
- Port 22 inbound and port 443 inbound to facilitate connections to the virtual machines
- From the VPC to another VPC:
- Port 445 inbound/outbound [Optional for SMB Connectivity]
- At least one subnet
- DNS connectivity
- AWS EC2 Service Quotas for provisioning instances in the associated region
Connect your local network and AWS environment If your Ansys license server is located on a local network, ensure that a connection is established between the local network and the default VPC created by the setup as well as any additional VPCs that you have created. There must be a secure and private connection between your local network and the AWS Virtual Private Cloud. AWS recommends site-to-site VPN or Client VPN. Learn more about Amazon Virtual Private Network.
- The topic ‘Ansys Gateway powered by AWS – Express Setup Overview and Prerequisites’ is closed to new replies.
6029
