July 6, 2023 at 12:52 pm
fares abbara
SubscriberI ran an FSI model overnight and when i came back to check on the solution i have found the solution to be done. The message log specified that the simulation ran successfully (4 hours ago) in the project schematic. However when i was checking the transcripts for the FSI solution i have seen that the transcript was stuck at the point shown in the picture i attached. transient structural progress bar shows "(99%) preparing the mathematical model". I tried to interrupt the FSI solution to at least have access to the solutions, however nothing happened. What should i do so i won't lose the solution files and i could still access them ? i cannot run the simulation again since it is time consuming (9 hours).
I am running ansys on an HPC cluster.Â
July 14, 2023 at 8:54 am
Rahul
Ansys EmployeeÂ
Hello
From the image attached, I can see that the solution is complete.
Could you please share the image of participant log files as well to understand the issue?Regards,
- The topic ‘ansys froze after my solution ran complete’ is closed to new replies.
.png)
