February 16, 2023 at 4:48 pm
Josh Klingler
SubscriberHello,
I am the IT guy at our university.
When we run a file from a network drive, we often get these errors:
Running the file locally does fix it. Â
This is not an acceptable solution for our professors though. They need it to run from the network drive.
We tried versions 2022 and 2021r2, both do the same.
We triple checked permissions to the network share.
Thanks for any help
February 21, 2023 at 2:43 pm
George Karnos
Ansys EmployeeWhat program/file are you trying to run?
Can you post the error pics as we are not permitted to open files. -
February 21, 2023 at 3:35 pm
Josh Klingler
SubscriberHello,
Thank you for your reply!
Here is what the professor told me:
We tried to use ANSYS2022 - "Static Structural" to solve static structure models. There should be nothing wrong with the models. The error message is "An error occurred when the post processor attempted to load a specific result. Please view all messages''. Along with a warning message "Current result file may not contain requested result data. Please clear the solution and solve again" and "The result file can not be opened".
- The topic ‘Ansys From Network Drive’ is closed to new replies.
5984
1307
