February 24, 2023 at 2:33 pm
KELVIN KOECH
SubscriberHello team. I am Kelvin Koech, a student studying aeronautical engineering. I am working on a project dealing with compound engines; integrating piston engine system and turbine assembly to the exhaust system. I am looking at the aerodynamics and structural implications of the design. My question is; is it possible to integrate the Ansys Forte CFD simulation with the Ansys CFX/Fluent simulation, so that the effects of piston engine pulsation is fully captured? I will appreciate any help or guide on how to work on this. Thank you in advance
March 1, 2023 at 7:37 am
Nikhil N
SubscriberHello,Â
You may want to explore Ansys System Coupling: Ansys Product Help
Also, check the participant support and the transferable quantities here: Participant Support of System Coupling Capabilities (ansys.com)
If you are not able to access the above links, refer to this forum discussion: How to access the ANSYS Online Help
Thanks!
Nikhil
April 10, 2023 at 4:57 am
Abhikrishna Ravi
SubscriberHi, I'm Abhikrishna Ravi, a Mechanical Engineering final year student. I'm currently working on H2-Diesel dual fuel RCCI combustion. As part of the simulation we're using ANSYS Forte. We plan to work out the closed combustion modelling of the respective engine we're working on. We have don e mock simulation with the help of ANSYS tutorials and User guide. Unfortunately, the simulation is getting failed for us. We used the sector mesh generator for the purpose of making the cylinder sector and imported the bowl profile as well. Could we get some help from your side and give us some more insight on this? Regards, Abhikrishna Ravi -
December 12, 2023 at 1:57 pm
Abdelghani Noubail
SubscriberHello to everyone. I hope that someone can help me. I’m working on a project based on the tutorial chapter 2 "simulating a Diesel engine using sector mesh".  I have noticed that every simulation of mine, in the monitor section, the gross indicated work is always negative post process. Can you help me understand how I can change this?
- The topic ‘Ansys Forte and Ansys Fluent’ is closed to new replies.
