Ansys Forte
    • Anastasiia
      Hello!
      Does anybody know why is model so little? Why Forte loads it like that and what can I do with it?
    • jcooper
      Hi Anastasiia:nnIt looks like you have a material point way outside the model. There is a dot onscreen some distance to the right and slightly above your model The fit view will fit the screen to show both, making the model look really small.nIf you expand the Mesh Controls, you should be able to hide this material point by right-clicking on it and unchecking Visible. nThen, refit the view:nYou may want to correct the material point coordinates if this is something that was created by accident. You can further check your model scale by expanding the geometry section of the tree and checking various components as shown below, but I suspect that it is the material point that is the issue:nnn
    • Abdelghani Noubail
      Hello Everybody. Does anyone knows how i can simulate without combustion  the tutorial "Simulating a Diesel Engine Using a Sector Mesh"?
      I would to tranfere files output to Excel cell. How i can make it?
  • The topic ‘Ansys Forte’ is closed to new replies.
